Clutch problem..What is it with me and clutches? :-S
leeparkes
Fri Jul 02, 2010 8:42 pm
Cypriotgeeza wrote:Gearbox
Dont want to p1ss on your bonfire but thats NOT an M30 gearbox and it wont fit.
Only joking :snigger:
Good luck :thumb:
Cypriotgeeza
Fri Jul 02, 2010 9:31 pm
haha mate i was actually like 8O for a second..dont do that do me please! been through too much lately haha
thanx man :thumb:
Check my M30 build threads:
Fri Jul 02, 2010 10:45 pm
Lee you fu cker!! :twisted: , you nearly had me going, I looked, and looked again, and again. :mad:
Cypriotgeeza
Fri Jul 02, 2010 10:48 pm
Rav335uk wrote:Lee you fu cker!! :twisted: , you nearly had me going, I looked, and looked again, and again. :mad:
you and me both man! :twisted: !
Fri Jul 02, 2010 10:55 pm
You going to get this sorted by tomorrow?
leeparkes
Fri Jul 02, 2010 10:57 pm
Cypriotgeeza
Fri Jul 02, 2010 10:59 pm
Nah im going to go into work on my day off (on tuesday) and use my ramp to get it done..that way my managers there incase i run into some trouble..hes one of the best mechanics i've come across so if i have a problem its good knowing hes around
Fri Jul 02, 2010 11:04 pm
And what clutch did you buy, ~E34 one?
Cypriotgeeza
Fri Jul 02, 2010 11:08 pm
yep i bought this one:
and it looks exactly the same as what came off the flywheel i just bought so im hopeful that its the right one!
leeparkes
Tue Jul 06, 2010 9:04 pm
Have you done it? :D
Tue Jul 06, 2010 9:08 pm
All gone quiet :?
leeparkes
Tue Jul 06, 2010 9:57 pm
Probably still under it ripping his wig out with fury :banghead:
Cypriotgeeza
Tue Jul 06, 2010 11:52 pm
Well i was earlier...
untill i DROVE it home!!! :D :D :D
i cant understand how anyone can live WITHOUT an M30 in their life!!! obviously gave it an easy drive home as the headgasket is still fresh but the clutch is working perfectly and i cant be happier! i will get the pics up tomorrow as my digi cam died earlier! :(
the howl of that straight 6 was something else tho..def know why everyone says a 4pot isnt the same!
straight 6 all the way!
Last edited by Cypriotgeeza on Wed Jul 07, 2010 12:21 am, edited 2 times in total.
leeparkes
Tue Jul 06, 2010 11:59 pm
Nice one :thumb:
pm'd
Wed Jul 07, 2010 8:44 am
Well done, 'bout time :mad:
zaust
Zone day release
Wed Jul 07, 2010 6:16 pm
Get a sound clip up with the pic's.
M30 Tech 1 Touring on gas.
Cypriotgeeza
Wed Jul 07, 2010 7:23 pm
zaust wrote:Get a sound clip up with the pic's.
i will do once im driving it properly! here are the pics:
"frankenstein box" still has the gear linkage attached:
Flywheel difference:
looks like my idle/irregular revving is due to a faulty Idle control valve as i can move the valve inside just by shaking it :mad: im assuming this should only be moved electronically?
leeparkes
Wed Jul 07, 2010 9:08 pm
Is the Franky gearbox the same length as the E34 one, ie did the prop fit ok?
Cypriotgeeza
Wed Jul 07, 2010 9:10 pm
leeparkes wrote:Is the Franky gearbox the same length as the E34 one, ie did the prop fit ok?
I think it is.. it looked longer on the car and the gear linkage/ gearstick sat back a bit further then where it is now but next to each other theres not much in it
leeparkes
Wed Jul 07, 2010 9:25 pm
Cypriotgeeza
Wed Jul 07, 2010 9:27 pm
leeparkes wrote:Image
:teehee: !!!! i might print a little version of that and stick it on one of my windows hahaha
leeparkes
Wed Jul 07, 2010 9:29 pm
Check his limp wrist :gay:
Cypriotgeeza
Wed Jul 07, 2010 9:33 pm
haha nah thats him just waving off the competition
Wed Jul 07, 2010 9:42 pm
Finally , the 2 sat side by side look minutely different.
Cypriotgeeza
Wed Jul 07, 2010 9:50 pm
Rav335uk wrote:Finally , the 2 sat side by side look minutely different.
its the way my manager was like "They dont look very different if you ask me" haha its the fact that i dont know where or what it came from that got me..
now i know i have everything E34 so there will be no confusion!
Cypriotgeeza
Wed Jul 07, 2010 9:51 pm
plus one writes "good gearbox" on it which makes all the difference if you ask me :snigger:
leeparkes
Fri Jul 09, 2010 8:31 am
iirc M20 idle valves are the same as M30, might help your hunt for one
Double check the part numbers though.
Cypriotgeeza
Fri Jul 09, 2010 10:51 pm
leeparkes wrote:iirc M20 idle valves are the same as M30, might help your hunt for one
cheers mate :thumb: yea just looked and its the same part no. and the same price 8O cotswold quoted me £200 for a new one 8O 8O madness!! :mad:
Fri Jul 09, 2010 10:57 pm
I should have one here somewhere, will have a look in the morning.
leeparkes
Fri Jul 09, 2010 11:09 pm
Why do you need a new ICV, if you got a dodgy idle it could be an air leak.
Dont forget youve had the head off and disturbed a lot of things
Cypriotgeeza
Mon Jul 12, 2010 11:40 pm
leeparkes wrote:Why do you need a new ICV, if you got a dodgy idle it could be an air leak.
it idles fine its when i rev it i get problems..like i said before if i rev it past 1,500 it will just fluctuate by around 500 rpm so i started unplugging things..when i unplugged the ICV i could rev it normally...also when i shake the ICV it feels like evrything is loose inside..is that normal?
Last edited by Cypriotgeeza on Tue Jul 13, 2010 12:13 am, edited 3 times in total.
Cypriotgeeza
Mon Jul 12, 2010 11:42 pm
stayed back afterwork today as my clutch on my iS also gave me problems on saturday!! It jus suddenly went hard and it was very hard to get it into gear..and everytime i pushed the clutch a LOUD screetching noise came out of it
here is the cause 8O
Me and clutches are not mixing at the moment haha :mad:
Mon Jul 12, 2010 11:47 pm
What again???
Cypriotgeeza
Mon Jul 12, 2010 11:50 pm
nooo this is my i.S :mad: i was driving back from my sisters on sat when it must have exploded! just let out a loud screetch and the pedal went hard!
not driving the 3.5 yet as it isnt insured or tax'ed yet
Tue Jul 13, 2010 12:27 am
Oh the 4 pot, can't help you there, never bothered to learn about them :mad:
