M30 project for TTT...It Runs!!! 30/6/11
- E30 Zone Meets/Events Team
Wiring
Using the M30 engine loom, some minor modifications are needed... Temp sensor - the brown temperature sensor on the M30 block will need swapping for an E30 (M20 only?) item.
Extend coil connection - you'll probably find the coil will need to move, & the 2 (non-HT) connections to it will need extending. Not a difficult job, & best left until you know exactly where you'll mount it & how long they need to be.
Facelift wiring mods (these apply to those with a facelift shell) - the engine will run without doing them, but for everything to function correctly, the following are needed;
To get the 'economy swingometer thingy' working you need to swap pins in the M30 loom:
Pin 3 (black and white) and pin 8 (black and purple).
To get the electric windows and sunroof to work with the doors shut and for the heater blower to work at all you need to connect the black and green wire from pin 15 on the E30 C101 to a small spade connector on the starter motor.
rev counter
rev counter
charlE30
With a bit of help from a hammerricey46 wrote:Nowt really to prepair, it just squeezes in!
I can't offer any advice with regards to wiring as I've never dealt with pre-facelift
ricey46
The wiring is fine, swapped the temp sensor, just need to swap the two wires for the econometer. And it has no electric windows.
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
leeparkes
Did you sort the prop out?
how far do the splines go in on that one in the pic, if they dont go in far enough it wont last long.
320Touring
Looks brilliant-cant wait to see this in the flesh in the weekend
ricey46
I was worried about that too, they are in about 20-30mm, not sure if that's good enough for that!? That prop doesn't fit very well anyway, the center bearing won't bolt in as it should.leeparkes wrote:Did you sort the prop out?
how far do the splines go in on that one in the pic, if they don't go in far enough it wont last long.
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
ricey46
Feel free to fire it up for a minute or two, it'll start off the key!!320Touring wrote:Looks brilliant-cant wait to see this in the flesh in the weekend
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
johnl320
I have used this combination but have made new centre bearing mounting holes just forward of the origonal ones, but I don't seem to have that amount of exposed splines, are you using a medium case diff? I am which may be why
ricey46
Yip the 3:64 LSD is in at the mo.
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
ricey46
Had a good raid around the scrappies at you pull it today, managed to get an e34 wasger bottle that'll fit and I picked up two huge fans from a Renault Saffrane, and another from a Saab 900, so I'll see what will fit best.
Also what thermo switch that goes into the rad do I need to pick up, and what from??
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
johnl320
I'm using a 1996 525i twin temp sensor mounted on the side of the rad
Jonas
Alrite chief!!!! what news of the m30 as of late? It looked sweet as fook when I was last up at the unit, sounds amazing in the vids too
Jp
Jp
ricey46
Well after almost another year, it's almost complete, just a few small things to do. Here's a couple of crappy phone pics for the moment, I'll get some better pics up on Monday with a video or two aswell.
To Do List...
1.Wire up rev counter. - What are the correct wires to connect for this or is it just trial and error??
2.Get MOT
Paul.
To Do List...
2.Get MOT
Paul.
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
320Touring
WIN!
Dunno if your m10 cluster has the coding plug?
If so, Its different between 4pots and 6's
ricey46
it's got a 6 pot plug in it Neil. Just need to know what wires to connect.
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
Jonas
Looking good chief!
Did you get the lumpiness sorted?
Jp
Jp
rob0r
Nice project
. What did you end up doing with the prop?
leeparkes
About time
Did you swap the two wires over on the loom? iirc that controls the rev counter....
+1 on the prop specs
ricey46
Jp- Almost, cleaned the AFM and reset the valve clearances, cleaned the plugs and sorted a couple of air leeks. Almost sorted but still misses, will have a better look at the weekend.
Lee- nope I've not swapped the wires yet as I thought they only controlled the mpg gauge and the electric windows and fan, but as I'm not fussed about the mpg, I don't have leccy windows, and the fan works, I didn't bother. I thought It was to do with the white 3pin plug that is below the cluster, Square type plug??
The Spec is....
M10 box, clutch and flywheel
325 rear half of Prop
320 front half
M535i rad
Saab 9000 fan, butchered to fit, with e36 thermo switch and over ride switch on dash too.
Only thing is the temperature the switch operates at is a little high, I think around 90degrees, so the temp gauge is about the 1o'clock mark before it cuts in!?:roll:
The Spec is....
320 front half
M535i rad
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
