M30 conversion guide - WIP; input required!
scottidog
Sun Aug 16, 2009 1:20 pm
does this mean beefy is no longer selling these mounts, he shouldnt let one nob upset him!
Thanks for the measurements i will compare with my rad today. Just wish the rain would hold off.
You win some, You loose alot!!!
chris_335
Sat Aug 29, 2009 2:37 am
eva finde out if any 1 has done a auto if no im on it and looks to be going ok so far
the only thing is the slector on the m30 auto box is cable so there is a few small holes just under the carpet pop one out put the cable through the slector its self i used a e34 and droped in to the e30 where the old one was simple will post pics at some point
scottidog
Sat Aug 29, 2009 1:59 pm
Hi all, i cannot see a brown temp sensor on my m30 block to swap for an m20 item as described at the beginning of this thread. I only have a black one and a blue one, do i swap it for the black one?
Thanks in advance, Scott.
gooner1
Out humping Reindeer
Sat Aug 29, 2009 2:21 pm
scottidog wrote:Ok defo need mounts now im stuck, where can i get them???? I have mailed beefy but no reply.
Google Spox motorsports Scotti, they make them, bit expensive though.
scottidog
Sat Aug 29, 2009 3:07 pm
i have made my own mounts, made them out of wood and got local engineering firm to copy them out of steel, cost £90.00. Just a little unsure about this brown temp sensor now!
Baurluvva
Sun Nov 15, 2009 1:48 pm
Have a look at pictures on 1st page for brown temp sensor position! :D
Sun Nov 15, 2009 5:38 pm
It'll be the black on then, as the Blue/Brown are next to each other at the front of the block.
Elmoowen
Sun Nov 22, 2009 10:22 pm
Hi guys,
sorry to thread-jump.I'm just about to start an M30 swap on an '89 316.
I'm currently concerned about the wiring swap, i have a running E34 535i to put in o thinking of swapping the whole loom in.
I'll get on the new members thread and let everyone know my plans..
leeparkes
Mon Nov 23, 2009 5:11 pm
Use the M30 loom, it plugs straight into the E30 body loom
you need to swap two wire over on the M30 loom to make it run correctly, its all on the first page of this thread
Welcome btw.
kms_racing
Sat Nov 28, 2009 11:51 am
just done my conversion , the thread made the job a doddle, made up my own solid mounts and will be producing them for £75 a set ,solid and non solid versons for use with e30 rubbers , i was very impressed that there wasnt much vibration with solid mounts
nick
kabeer
Wed Dec 16, 2009 4:46 am
Hello guys,
Another thread-jump......i'm preparing a complete M30 HISTORY, but need to post at first page.. :D
Proud to say, First E30withM30 in Kuwait.
leeparkes
Thu Dec 17, 2009 6:10 pm
Just a note on this thread i am now supplying M30 mounts for the conversion
Jean
Tue Feb 09, 2010 7:14 am
Good thread! My ECONO/MPG gauge does not work after I did the swap.
"To get the 'economy swingometer thingy' working you need to swap pins in the M30 loom:
Pin 3 (black and white) and pin 8 (black and purple). "
I will give this a try...
Baurluvva
Tue Feb 09, 2010 10:20 am
leeparkes wrote:Just a note on this thread i am now supplying M30 mounts for the conversion
Please can you post up pics of both solid and non?
Baurluvva
Tue Feb 09, 2010 10:21 am
kms_racing wrote:just done my conversion , the thread made the job a doddle, made up my own solid mounts and will be producing them for £75 a set ,solid and non solid versons for use with e30 rubbers , i was very impressed that there wasnt much vibration with solid mounts
nick
Please supply pics of both!!
D3mon_Hunt3r
Wed Mar 31, 2010 11:30 pm
One doubt i have an 89' 316i M40 Coupe LHD the headers/manifold won't have problems with the steering coupling/linkage right? Will it (the engine) conflict with something else?
Regards
leeparkes
Wed Mar 31, 2010 11:54 pm
Im not 100% but i think you will be ok, linkage is quite low down and manifold is quite high up
Is the brake servo the same as RHD
Here's a pic of the space you have down there
D3mon_Hunt3r
Thu Apr 01, 2010 12:27 am
Yes the engine bay is almost empty. :P
The servo is the round/oval black casing near the brake master cylinder right?
A e32 brake master cilinder i've read its a perfect fit for an upgrade of the e30 one, will it fit with this engine swap?
jessy
Mon Jun 20, 2011 12:22 am
really very nice info hare...cheers everyone....
i have new bmw!
walinsky
Wed Jan 25, 2012 5:23 pm
FYI
Frank Malusco offers his M30 swap writeup for free now @ the neighbors.
http://www.r3vlimited.com/board/showthread.php?t=231570
The pdf has some pretty useful info!
Minstrel
Wed Mar 14, 2012 5:33 pm
Excellent guide! I am planning to do a M30b35 conversion next month hopefully! The only part I didn't understand is about the M20 engine loom? Is this just plug and play or do I have to use a M30 engine loom? I'm probably being a numpty :/
dubownerbilco
Mon Jul 02, 2012 8:43 am
morning all :)
not sure if this has been mentioned yet but its early so i cant concentrate long enough to read the full thread yet!
what should be done with the front suspension on my touring as it will obviously be far too soft to cope with the m30 (currently a 1.6) it is lowered around 60mm and i would like to keep it that way :)
leeparkes
Mon Jul 02, 2012 4:09 pm
Mine dropped about an extra 5mm on the front with normal 6 cylinder springs so if you buy 40mm springs with some E90 tophats you should be at a 60mm drop. (E90 tophats lower it by 15mm)
jimbom30cab
Tech 1 freak
Mon Jul 02, 2012 4:25 pm
Do you know Lee what Aplina springs and shocks were used in their M30B35 cars ? cheers
leeparkes
Mon Jul 02, 2012 4:28 pm
There is a list on here somewhere of spring rates shocks etc of all E30's but its been a few years since ive seen it.
fixedwheelnut
Fri Nov 23, 2018 12:53 am
DRIFTBOY wrote:
Sat Apr 05, 2008 2:03 am
Yeah, the cheapness of 3.5s makes the under-powered 3-litre a waste of time really.
I've had E36 and Z3 racks (exactly the same externally) and with an M30 it's a headache! :(
On sudden hard left hand turns my exhaust manifold leans nicely on the steering coupling, locking the steering! :eek:
Not nice, so I'm very careful.
Extensive manifold modifications are required, and stiffer engine mounts could help too but I've not got round to that yet.
I'm not too fussed about sorting the problem as I'm currently working on a turbo conversion that should sort out that problem anyway.
Pm sent Ziggy! :)
I have the M30 3.5 it already had a six branch on it when I bought it and I had the same trouble hitting the steering column shaft on a hard left bend, this is with a purple tag rack, I had some aluminium spacers made to use with Rover V8 engine mounts that made it a lot stiffer and stopped the engine shifting over :thumb:
