My M30 conversion
Bristol_Jer
Post Thu May 05, 2011 9:31 pm
http://bmwfans.info/parts/catalog/E34/S ... air_valve/
It's to do with a fuel tank breather, can't seem to find what the electrical connector is for on it though. Just going to disconnect it all, block up the breather pipe and see what happens. This engine is proving to be a bit of a pain in the ass!
Have done a few more jobs tonight, fitted my new Bimmerworld uprated engine mounts, and did some more on the coolant hoses going to the matrix. The hose that goes into the bottom part of the matrix I modified. I cut the bottom part out here:
And then fitted it back onto the hose like this:
Is that a similar sort of thing to what everyone else has done? Works well on mine, though will get some sleeving for it as it looks like it will rub on the underside of the inlet manifold.
I have fitted the top hose straight on, although I'm not happy with the routing of it as it touches the servo and inlet manifold, so will modify this one too I think.
Post Thu May 05, 2011 9:35 pm
IIRC, mine is one peice, I didn't cu ino any of the hoses on mine, all I added was the "T" piece.
Bristol_Jer
Post Thu May 05, 2011 10:18 pm
I thought it seemed too long on mine, and went at the wrong angle to fit nicely.
Working all weekend so won't be able to do much for the next few days :(
leeparkes
Post Fri May 06, 2011 12:13 am
If that thing is a fuel tank breather pipe it will be plumbed into the inlet somewhere so will need blocking off.
Where youve joined that pipe you need to put the T piece in to get a hose to the coolant bottle, then this pipe goes to the 'top' matrix stub and it runs over the servo.
Imo id sack that loom and get one from another M30, im sure all M30 looms are the same, ie one from a 530i, it would probably be less stress to graft an M20 loom in :)
Bristol_Jer
Post Fri May 06, 2011 7:06 pm
Its the other pipe Lee, I've already done that one :)
Also, you are right, the pipe goes into the bottom of the inlet manifold, next to the pipe that goes to the ICV. What a strange engine I've got myself.... 8O
I'm going to give the loom modification a go, I'll have a friend standing by with a fire extinguisher when I connect the battery up!
Bristol_Jer
Post Tue May 10, 2011 7:43 pm
Has anyone got a pic or any info on the 2 relays on the loom next to ECU please?
Post Tue May 10, 2011 9:18 pm
DME relay and fuel pump relay iirc, mine are located by the battery.
Bristol_Jer
Post Wed May 11, 2011 8:35 pm
Ok thanks Rav, the auto-electrician who works with my Dad is going to get me some relays hopefully. That should be the last bit of loom to do then I can try and start it up :)
I fitted my refurbished gear linkage with z3 shifter tonight, feels nice and tight now. Going to offer up the 328 prop tomorrow after work and see what needs doing to the centre bearing.
Post Wed May 11, 2011 8:36 pm
The relays should be White(DME) and orange(Fuel)
Bristol_Jer
Post Wed May 11, 2011 8:39 pm
leeparkes
Post Wed May 11, 2011 10:51 pm
With the 328i prop you fit the centre bearing to the front half of it, some say reverse it but apparently it will make it out of alignment.
charlE30
Post Thu May 12, 2011 6:32 pm
Bristol_Jer wrote:Thats confirmed what I just found on the internet then :D
http://www.bmwpartsweb.com/BMW-Parts/Re ... 37275.aspx
I've got a couple of bags of relays from cars gone past (all E30's) and may well have both relays you can have for a donation to the zone to cover postage, can check after work tomorrow if you want :thumb:
Good luck with the prop :D
Charlie
BMW F31 335d xdrive
Bristol_Jer
Post Fri May 13, 2011 6:05 pm
Got the relays sorted now, thanks anyway Charlie :)
Didn't have a look at the prop in the end, forgot it was my girlfriends Grandad's funeral yesterday afternoon so much drink was consumed afterwards and not in a fit state for e30 fettling! Going to give it a go tomorrow afternoon, got a few bits to get from BMW in the morning for the car.
Bristol_Jer
Post Thu May 19, 2011 8:04 pm
From what I can see with the prop, if I put the e30 centre bearing on the e36 prop, then it should fit. The centre bearing is on the front half of both props.
Very close to getting it finished now, wiring is all sorted (hopefully!) and cooling sysem plumbed in. Got some more photos I need to upload soon.
Do most people have to bash a bit of the floor/bulkhead back a little to fit the downpipes in?
leeparkes
Post Thu May 19, 2011 8:58 pm
Bristol_Jer wrote:Do most people have to bash a bit of the floor/bulkhead back a little to fit the downpipes in?
Yes it is tight in there but its only the sound deadening that needs squashing a bit to get the downpipe on.
Bristol_Jer
Post Fri May 20, 2011 10:56 am
Sound deadening is in the bin :)
Just got to put the exhaust manifolds and downpipes back on when I get the fixings and then it's time to try and start it up :D :D
charlE30
Post Fri May 20, 2011 1:28 pm
Bristol_Jer wrote:Sound deadening is in the bin :)
Finished for lunch tomorrow then winkeye
BMW F31 335d xdrive
rob0r
Post Fri May 20, 2011 2:06 pm
Nice project 8).
Where exactly does the bulkhead need massaging? My engine bay is empty so it would be better to do it now. Here's my bay and the sound deadening is destined for the bin.
zaust
Zone day release
Post Fri May 20, 2011 5:33 pm
It's must to start it with out the exhaust system fitted even if you have done so already...
With just the manifolds it is such a nice sound :)
M30 Tech 1 Touring on gas.
Post Fri May 20, 2011 6:26 pm
rob0r wrote:Nice project 8).
Rob, the bulkhead just above the Gearbox tunnel on the driverside, neads a little massage mate, and remove all the transmission sound proofing, it'll make it easier to work on the gearbox later if need be. :D
Bristol_Jer
Post Sun May 22, 2011 3:11 pm
What oil are you suppoesed to put in the gearbox? It is from a 1990 535. There is an orange sticker on the side of the box that says ATF, but the rest of the writing is rubbed off. Does this mean use ATF or don't use ATF? :?
charlE30
Post Sun May 22, 2011 4:12 pm
My sticker states to use ATF fluid. Just checked the bentley manual and it's not definate, it states " gear oil or ATF dependant on year and application" :mad:
I've always used ATF in the M30 manual box
BMW F31 335d xdrive
Bristol_Jer
Post Sun May 22, 2011 4:36 pm
Thank you Charlie :)
I've ordered a bigger puller to get the centre bearing off of the prop as mine was too small, then hopefully I'll have the prop sorted. Been away all weekend at a car show so no progress on the car this weekend :( Saw a nice turbo'd M30 E30 at the show though, very nice, looked quick on track too winkeye
leeparkes
Post Sun May 22, 2011 10:12 pm
I was in the same boat as you a while ago :D
http://www.e30zone.net/modules.php?name ... hlight=oil
Bristol_Jer
Post Wed Jun 01, 2011 9:18 pm
Better write an update! :o:
Have got my e34 throttle cable fitted now, what a bitch that was to get the old plastic grommet out the bulkhead! Had to drill the thing out in the end then hit it out
The m535 radiator fitted nicely, used a e28 m535 bottom hose
Got the z3 shifter fitted with all new gearshift parts. Sits in the middle of the hole in the floor, although it doesn't look like it in the pic
Clearance between the rad and dizzy cap is not too bad, have got uprated engine mounts so hopefully the engine won't move around too much!
My radiator hasn't got a temp sensor fitted, or a threaded part to fit one. Can I put a sensor in the middle part here to trigger the fan? Also, is the black one the one you need swap for the single pin m20 one?
Unfortunately a few of the hoses on the induction side are starting to split so need to replace these sometime soon :cry:
Post Wed Jun 01, 2011 9:26 pm
Regards to the temp switch, yes change for the M20 brown one.
The fan switch on mine is where you want to put it now, between the two other swtiches.
leeparkes
Post Thu Jun 02, 2011 12:08 am
Arnt they temp switch holes at the top of the rad?
Nice progress btw 8)
Bristol_Jer
Post Thu Jun 02, 2011 5:55 pm
Yes Lee, thats where they would be but it is just solid plastic, not threaded unfortunately :(
Rav, the fan works ok running it off of the middle sender then? Doesn't ever get too hot? I'm going to get it wired up so the fan comes on with the sensor when hot enough, but also have a manual override switch in the car
Post Thu Jun 02, 2011 6:15 pm
Do you have an 80 degree stat fitted???
I do, and the fan kicks in when it's just over halfway on the temp guage.
Bristol_Jer
Post Thu Jun 02, 2011 8:44 pm
Not sure to be honest! Haven't taken it apart to look. Did you just use a normal BMW fan sender, nothing out the ordinary?
Just got to sort the fan and that should be the wiring done as long as I've connected my c101 plug wiring properly!
Post Thu Jun 02, 2011 9:02 pm
No I used a Ford switch, 2 pin one with a low reading point on it.
Will see if I can dig ut the number for you.
Bristol_Jer
Post Thu Jun 02, 2011 9:05 pm
Ok cheers mate, is that a 2 speed sender then if it is a 2 pin?
Post Thu Jun 02, 2011 9:08 pm
No single speed only.
Bristol_Jer
Post Mon Jun 13, 2011 9:32 pm
Carpet is out, battery in boot kit fitted, exhaust downpipes fitted, ready to start, but needs a new battery! :roll:
Pics to come when I get a chance to upload them
Post Mon Jun 13, 2011 10:04 pm
Dude, didn't find the numbers for the temp switch, i've got it written down somewhere, will keep looking. :?
