when fitting a 328 manual prop !
guide say reverse centre bearing !
do i fit the e30 centre bearing reversed
or reverse the e36 328 centre bearing ?
thanks for any help
328 prop
Bristol_Jer
That bit confused me too, I just offered up the centre bearing and it all fitted fine, didn't need to reverse anything! Make sure you pre-load the bearing when you fit it.
Bristol_Jer
Sorry yes I should have said more clearly, I used the 328i prop with a new e30 centre bearing the right way round!
- Cypriotgeeza
Im guessing this was a 325i centre bearing?Bristol_Jer wrote:Sorry yes I should have said more clearly, I used the 328i prop with a new e30 centre bearing the right way round!
Im looking to replace mine as it has an e36 bearing on there and the heatshields no longer fit because this bearing sits lower
Check my M30 build threads:
Bristol_Jer
I can't remember which e30 one it was, but have a feeling most if not all e30 centre bearings are the same?
Bristol_Jer
- Cypriotgeeza
Nice one thanx for that mate!Bristol_Jer wrote:Yep just checked, same as e34 and e32 too
http://bmwfans.info/parts-catalog/26121226723/
- Matty-Westside
Yeah its the e30 centre bearing reversed. Confused me too as I reversed the e36 bearing first! The reason for reversing the bearing is because the bearing mount is offset on the opposite side to the e36 bearing mount. So by reversing it, it lines up better with the e30 chassis.
