Thermostat removal
garthy327
Post Mon Aug 24, 2015 6:14 pm
Does anyone have a secret on removing the Thermostat housing?
I am replacing a broken one on my M20 and I just can't get the bugger off.
Gareth
zd3bx
Post Mon Aug 24, 2015 6:43 pm
You mean just the face or the complete housing? The outer part is just 3 bolts and it's off? Could be slightly stuck, but should easily pry out with a screwdriver?
garthy327
Post Mon Aug 24, 2015 8:33 pm
I mean the complete housing. The housing is on 2 studs and I have managed to move the top of it alittle but the bottom is just not moving.
Screwdriver, Hammer, the lot.
Nightmare.
Post Mon Aug 24, 2015 10:26 pm
Corrosion on the studs is the problem. WD40, or whatever you prefer, into the space around the studs, and keep it moving. It'll evenyually come loose.
