maf convertion
gafta
has anyone here done a afm delete and replaced with a maf meter instead? im seeing miller performance do this but there prices are very steep in my opinion.
jimbom30cab
- Tech 1 freak
Yes, only do it if you are prepared to spend £500 or more on a proper mapping session. The Millar chips are not ideal.
My advice, save you ££ and go on holiday instead.
Kedge
You didn't rate it then Jim?
jimbom30cab
- Tech 1 freak
Well, the off the shelf millar maf and chip has a map which is quite lean. It would be good i think but needs proper mapping ideally. I tried a few different chips and actually the Millar is the best one out there.
Not to worry, i'll get it off to Gunni in the new year
Kedge
Got ya. I've not tried mine yet, going to stick with the AFM until I take mine for a proper mapping session and will try and get a map done for both.
