m20b20 dyno results
TheMeathead
Post Mon May 26, 2014 11:12 pm
so i put my e30 on the dyno down at jrm motorsport (the old sumo power building down in rye east sussex)
i thought i would see what sort of power the old girl was putting down, i know the b20 doesn't have many fans on here tbh. They also don't seem to make very gd power.
So i was very suprised to see my car pull 121.6 bhp and 119lbft at the wheels. now from what ive been told bmw's normally have a 15-16% transmission lose which make's about 140bhp and 138lbft of torque at the flywheel.
i was pretty pleased to say the least :)
Post Mon May 26, 2014 11:15 pm
Impressive stuff. 8)
Is that with the stock management/chip?
jimbom30cab
Tech 1 freak
very nice indeed, a good result !
TheMeathead
Post Mon May 26, 2014 11:33 pm
it has one of you speedtouch wild chips on it and a b25 throttle body, the dyno opp said its got a rich spot between 2700-3200rpm. Thats the reason the torque curve is a bit wobbly apart from that he said it was spot on and was very impressed
reggid
Post Tue May 27, 2014 8:57 am
lambda 1.19 is about 17.5:1 AFR which is lean but doesnt seem to be causing any power delivery issues.
looks a reasionably healthy specimen anyway
E30 325is with M20B31
Post Tue May 27, 2014 9:52 am
TheMeathead wrote:it has one of you speedtouch wild chips on it and a b25 throttle body, the dyno opp said its got a rich spot between 2700-3200rpm. Thats the reason the torque curve is a bit wobbly apart from that he said it was spot on and was very impressed
That's good to hear, dude. :thumb:
