Rocker arm lock
Mindelis
Hi, at the moment i am rebuilding m20b25 engine. And now i put head all back together and can you tell me how can i lock rocker arm shaft in position. I have this locking thingy to lock it in the side where is camshaft pulley, but i dont know what part i need to lock other end of rocker arm shaft?
maggspower
- Turbo Farmer Tractor Driver
It only gets locked on the cam end with the little tab you have.
Contact: theengineshedonline@gmail.com
it only needs No6 as shown here,
it should fit snug, the rocker cover holds it firm in place,
ross2009
theres 2 slots in the shafts you have to line them both up so there vertical only then will the locking key go on
