Oil pressure
VW-will
Post Sun Dec 04, 2011 2:38 pm
Hi guys next too the oil pump Theresa big nut with a spring loaded pipe coming out, what's this? Thanks
ezagood
Post Sun Dec 04, 2011 7:39 pm
its not the drive for the pump is it?
Post Sun Dec 04, 2011 9:17 pm
Are you meaning next to the pump with the sump off? Oil pressure relief valve screws into the bottom of the block.
VW-will
Post Mon Dec 05, 2011 11:14 am
Could it be this has taken a hit, and why my oilpressure is lower at tick over?
ross2009
Post Mon Dec 05, 2011 8:39 pm
oil pressure will always be lower at tick over as you pump pumps more as the revs rise as its driven by ya cam belt
Turbo M20
v8 project 6.0 twin turbo
VW-will
Post Mon Dec 05, 2011 11:46 pm
It's lower than it was before the hit, found the prob anyway... Crack along the seem of the oil pump to the block new pump gona make sure it runs good tomorrow and then can sell it :-)
