2.8 build which head ????
JAFF
Post Sun Aug 28, 2011 1:48 pm
hi all , in the process of getting all the bits for my2.8 build ,just wanting to know what the best combination of head to use an 855 /731 and what cam's can be used to uprate them ,and on that note im still after the con rods :D
JAFF
Post Sun Aug 28, 2011 10:54 pm
any one ?????/
toby
Post Sun Aug 28, 2011 11:03 pm
885 head
You've seen this? - http://www.e30zone.net/e30zonewiki/inde ... ding_a_2.8
Cam is your choice but around 272/272 is frequently claimed by a few to be the best all round choice. Others like goosiegander have used slightly higher lift ones.
**BANNED**
Post Mon Aug 29, 2011 1:25 am
Head choice should be ruled by piston selection.
All 2.8's built to date seem to have used 325i pistons/885 head.
Youth is wasted on the young.
rossmc88
Post Mon Aug 29, 2011 1:37 am
looks like you'll just have to buy my lovely refurb'd 855 head :)
reggid
Post Mon Aug 29, 2011 3:51 am
i would go 885 unless you spend alot of coin to get the 731 to flow like the 885 which requires oversize valves for the 731 as a minimum. A 731 head with the same flow as a 885 usually would have smaller ports for the same flow which keeps the port velocity higher.
E30 325is with M20B31
JAFF
Post Mon Aug 29, 2011 9:25 am
thanks all i know which route im going to take then :thumb:
Post Mon Aug 29, 2011 9:40 am
i've still got the m50 rods here, exactly the same size as M20 ones, if a touch lighter
JAFF
Post Mon Aug 29, 2011 1:26 pm
Simon13 youve got P.M :D
