Hi boys and girls, Does any1 have any ideas as to where i could find some poly mounts or uprated rubber units? ive searced the net and was wondering if m50 mounts are dimentionally similar?
cheers in advance!
Performance m20 engine mounts (rubbers)
e301988325i
I said:
e30topless said:
lock the wife in there
- damageandyy
landrover mounts are used by many other groups for a upgrade as they are much tougher, and they are very cheap aswell, worth a look
e301988325i
That may be the ones he is referring to, but they are only 37mm, when standard is 50mm, if someone could measure a new engine mount to confirm please!!!!!!!!!!!
I said:
hey folks, ive just fitted standard components just now. I know they'll tear into shreds but at least the lump is in. I'll hunt the volvo items and get them on order for the garenteed failure of these ones. Cheers.
BigBavarian
- Contact:
Try Ford Escort RS2000 engine mounts, they are solid rubber and within a mm pf the standard set up, available from Burtons and very reasonable.
Richard
Richard
