318 TO 320 Swap
choochooman
Post Sun Jul 04, 2010 9:51 pm
Hello All,
I am thinking (only thinking) of swapping out my 318i lump for a 320i , whats needed ? is there a definitive list or how to on the web somewhere?. I am not sure what is needed apart from the engine and loom,i was thinking of buying a wreck for the engine and bits i need.
Duke137
Post Sun Jul 04, 2010 9:54 pm
Don't do it. Do a 325 swap or better still M50B25.
320i is slow and a waste of time
jmc330i
Post Sun Jul 04, 2010 10:52 pm
Unless you have a specific reason for using a 320i lump, like race regs or something, don't bother with it. You will use 325i levels of fuel and go no faster than your 318i is now.
Fit a 2.5 and be done with it. For either engine swap, you will need engine, loom, ecu, radiator, gearbox, prop and diff. Unless yours is a touring or cab, you should also swap the front suspension because the heavier engine with 4pot suspension is not great, I can tell you.
James
'91 325i Sport
'93 318i touring 16v
choochooman
Post Mon Jul 05, 2010 8:52 am
jmc330i wrote:Unless you have a specific reason for using a 320i lump, like race regs or something, don't bother with it. You will use 325i levels of fuel and go no faster than your 318i is now.
Food for thought there alright,
I wouldnt have thought there was not much difference in the 2.0 fuel consumption compared to the 2.5 lump.
jmc330i
Post Mon Jul 05, 2010 11:35 pm
Book figures state the 320i is a little worse on fuel compared to the 325i. I doubt there is really that much in it, but if I was paying for the fuel a 6pot drinks, I know which 6pot I'd have.
James
'91 325i Sport
