AFM delete
doyley123
Post Tue Mar 16, 2010 9:59 pm
Just wondering if the AFM can be removed for better airflow. Thanks Chris
fowler
Boost Junkie
Post Wed Mar 17, 2010 5:09 am
no but if you use Mega squirt you can run car alpha N good results to be had ....
Go to www.fastbimmer.co.uk and ring Ant @ A-Tech
EX A-Tech Workshop bitch !!!
gone but not forgotten
Gunni
Post Wed Mar 17, 2010 3:31 pm
In reality it can be removed for a MAF or MAP or even Alpha-n on the original motronic.
I´m working on a few solutions.
Gunni
@ 2012 VEMS group buy !!
doyley123
Post Wed Mar 17, 2010 8:33 pm
Just wondering if you could run a similar setup to an s14 with a carbon manifold, for a similar sound out of an m20?
Gunni
Post Wed Mar 17, 2010 10:42 pm
Sure you can.
Gunni
doyley123
Post Wed Mar 17, 2010 11:21 pm
So do you have to run throttle bodies then?
MillRat
Post Thu Mar 18, 2010 2:14 am
Miller MAF is a very simple and effective option. It is a direct replacement for the AFM, is designed for an E30 and wires into the existing loom. I run one on my E30 and it works a treat.
http://www.millerperformancecars.com/
You are only replacing the air flow sensor, not modifying any of the intake system, whether it be the phlemum, throttle body/bodies, etc... In theory, if you have a AFM, you can replace it with a suitable MAF.
Just be aware, the benefits of replacing the AFM with a MAF, or deleting the AFM with a MAP or stand-alone like Alpha N are not great on a standard car unless your AFM is cactus.
Cheers,
Michael.
AlpineAde
Post Thu Mar 18, 2010 2:16 am
Another big thumbs up for Miller here.
Good product, good support = good experience.
Gunni
Post Thu Mar 18, 2010 8:29 am
doyley123 wrote:So do you have to run throttle bodies then?
No not at all.
You can run your standard intake system.
Gunni
Ant
Retired Team Member
Retired Team Member
Post Thu Mar 18, 2010 10:58 am
fully variable auto TPS + std idle/wot and a remap of the stock motronic AFM voltage tables should be all thats required.
some tweaking of the accel enrich possibly, or MAF/MAP
all are possible but quite time consuming.
doyley123
Post Thu Mar 18, 2010 10:23 pm
so would putting the miller maf conversion on my alpina 2.7 be a good mod???
Gunni
Post Thu Mar 18, 2010 11:41 pm
honestly a very cheap piggyback and a TPS/MAF/MAP can do the same for less
Gunni
doyley123
Post Tue Mar 30, 2010 10:30 pm
so is this miller maf just plug in and play then?
AlpineAde
Post Wed Mar 31, 2010 1:00 am
Pretty much ~ except for about 4 wires and a touch of solder.
Have a look here:
http://www.millerperformancecars.com/tech-forum.html
Join up and post and you'll get every question you have answered. Or just email the guys. They're very good at answering correspondence.
doyley123
Post Thu Apr 01, 2010 6:58 pm
AlpineAde wrote:Pretty much ~ except for about 4 wires and a touch of solder.
Have a look here:
nice one buddy, il give that a try!
DmcL
Post Wed Apr 28, 2010 11:34 am
you can convert to use either a certain part numbered volvo MAF or hyundai MAF with motronic. there was a guy that set both up on his 325i in the states and made suitable maps tuned with a wideband. the volvo MAF requires 2 points on a 173 ecu to be bridged with a peice of wire but can support up to something like 300bhp whereas the hyundai unit will only support up to around 230bhp if memmory serves.
i have both maps saved on my laptop along with the map editing software but i havent found either MAF sensor yet and ive sort of put the MAF conversion onto the back burner as of late because i firstly need one of the MAF's and secondly need a chip burner, chips and wideband to monitor everything.
WMMotorsports
tomislav
Post Fri May 07, 2010 1:47 pm
Interesting thread, be keeping my eye on this for my 2.8 conversion
gafta
Post Sun May 30, 2010 9:09 am
Dose this maf convertion add more bhp? If so roughly how much ? winkeye
