New Air Filter Box with Rolling Road Results
reggid
Post Mon Feb 08, 2010 11:49 am
I have been playing around again this time with the standard air box and filter assembly. I wanted to increase the filter size and volume of the airbox and found this
http://rongineer.com/airbox.html
It is made for the E30 M3 using the flanges and clips off the standard upper section of the BMW airbox. It is meant to use the M3 Sports Evo lower half
http://www.e30m3project.com/e30m3perfor ... irbox1.htm
Since the lower half didn't fit in my car due to clashes with the radiator i was forced to make the lower half myself utilising the flange from an original.
This is what i ended up with
At the moment i have just got some silicon hose (45 degree tapered) for the entry to the lower airbox, will look to improve this later.
This setup uses a bigger panel size 318 x175x33 compared to the original 254x146x27
Dyno testing showed some improvements in the topend
Unfortunately my usual dyno place has new dynodynamics machine with new windows based system so i can't compare to my previous runs so this is sort of a new baseline.
There is only around 4rwkW peak to peak and in parts of midrange but past 5400 there is a noticeable difference of upto 10rwkW. You can see the difference in manifold pressure indicating that the pressure loss has been reduced.
E30 325is with M20B31
Royalratch
Post Mon Feb 08, 2010 1:32 pm
These Rongineer boxes are in a recent BMW mag, very good results but not cheap if I remember rightly.
Zoner 'Sheps' was in the same article and will know all about this.
