engine mounts
AdamGardner
Sun May 10, 2015 11:08 pm
Just wondered what mounts people are using for track/ hard use cars.
Im building a 325 tarmac rally car and would like to upgrade from the original rubber mounts. I have seen a few poly type mounts on the net but wondered what tried and tested routes there are?
Marneus
Tue May 12, 2015 5:14 pm
The revshift ones from hack engineering look good quality & there are plenty of US e30's running them. They come in different hardness compounds too.
bosers
Tue May 12, 2015 6:55 pm
They are great mounts, cheaper direct from revshift though. (sorry Hack)
fastdave
Thu May 21, 2015 4:53 am
Phil littleworth on facebook can get all the bits you need he helped develop the bmw challenge kit !
Sjon
Fri Jun 05, 2015 9:00 pm
PTFE / Teflon
60mm diameter
40 mm high
9,8mm hole
Works brilliant here
good luck!
Norbert
Sat Apr 08, 2017 10:46 am
I am using Teflon mounts from netherlands based company hartmann motorsport. Live the rigidity it gives in corners and the smoothness of gearshifts after installing it is delight! Cant say lost alot of comfort... In any case "because racecar". Using it for daily commute.
reggid
Sat Apr 08, 2017 11:37 am
for something a little better the stock, OE early m30 mounts are a slight upgrade
E30 325is with M20B31
