them fiats are a rapidgareth wrote: none of us, not even kos, will keep up with that fiat 126 so we're all losers
Santa Pod. Who's Doing the Quarter mile?
Kos
gareth
this must look odd to someone who hasn't seen that fiat in action!!!!
Andy335Touring
I know i'm not the fastest, the times are handy comparison's to see how your mods are doing, i should be faster since last year but that only depends if my latest mods work or not.Kos wrote:go to dissagree with that andyAndy335Touring wrote:The times not that important so long as you have fun and get a bit of a buzz from it and the banter
you spend all thst money on engine mods for just a buzz ?
i do it to be fast and prove i'm fast
The first few runs up the strip are a buzz so long as you have a few runs with a comparable car or just trying to beat the clock on your last run ?
o22ie
what sort of times could you be looking at with a standard 325
fuzzy
bit of both for me. its all good hearted racing and banter but its also about comparing your performance to more serious metal to see how far youve came and how much further you need to go. i know ill never have the fastest as money is much tighter these days due to the onset of domesticity but i just want something that can challenge at the mid power level.Kos wrote:go to dissagree with that andyAndy335Touring wrote:The times not that important so long as you have fun and get a bit of a buzz from it and the banter
Toby_Unna
- Boost Junkie
DRIFTBOY wrote: 12. Andy - Rover 114i
13. Toby - 205 diesel
Toby - aren't you running the 335i turbo ?![]()
we're both taking bmws Martin
unless i break mine first!
mattG
if you or dips don't use it i proberly willKos wrote:i'll be bring a recovery truck with me, who wants to book it for a lift home ??
Templ8e30
I'm not going this time but I went in June and managed 14.8 seconds @ 97 Mph.
I didn't bother with a burnout but should have, got a fair bit of wheelspin off the mark
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Nelly
- Gumbo
gareth
that's a good timeTempl8e30 wrote:I'm not going this time but I went in June and managed 14.8 seconds @ 97 Mph.
I didn't bother with a burnout but should have, got a fair bit of wheelspin off the mark![]()
Cheers,
Iain T
Templ8e30
I was a little surprised, I was up against an Evo 8 FQ300. I lunched him off the line with torque but he quickly overtook me and finished in the high 12's at about 110mph.
I found the tarmac to have less grip than road tarmac
Managed to crack the welds on my scorpion exhaust too, right where the 2 pipes exit the centre box. Made a right racket on the 150 mile trip home
Cheers,
Iain T
Cheers,
Iain T
Davenotouring
No way, Santa Pod it really grippy!
I'm going to run my Civic. I hope to drop into the 13's this time. I have done three runs since it's been 1.8, two of which were 14.0
Jhonno, challenge on?
BMW 328i Cab - Daily Slag
Kos
burn outs on raod tyers wont make a difference, you'll ned to smoke themfor anout 30 nseconds to make them sticky but they are not designed to work like that.
i've been up that strip hundreds of times, on raod tyres not many things you can do make any difference. and if anything too much grip bogs you down. and if you use slicks that grip from launch you 'll probably break something.
gareth
i was getting mine good and sticky for quite a while but then i had a trailer to go home on and the tyres were illegal before i even got there!
that said, it didn't seem to help! just fun
fuzzy
ive not done a timed run yet but ive often wondered if the burnouts helped on road tyres or if it was just the average joe playing at being a pro driver.Kos wrote:burn outs on raod tyers wont make a difference, you'll ned to smoke themfor anout 30 nseconds to make them sticky but they are not designed to work like that.
i'm sorry Kos but thats a load of sh!te, warming them up will make a difference to your time
Kos
unless you sit there for 30 odd seconds they wont heat up, by the time they do they will start tearing to shredsSimon13 wrote:i'm sorry Kos but thats a load of sh!te, warming them up will make a difference to your time
road tyres are exactly that si, road tyres and with well over 250 runs up santa pod in e30's i know what makes a difference.
even dropping you tyres preassure to below 20psi ( which i've seen done ) wont work. a few psi to get a wider contact with the track works but its minimal. you'll need at least 20 runs in one day to see what works for that particular day. sad but true, having been pit crew for a pro et team for 3 years i know a bit about this subject.
unless you are running 10x15 centre line wheels and MT rubber, forget it. but if you do and you launch it hard you'll break something !
doing big fcuk off mo-fo burnouts makes sod all difference on street tyres mate, a quick spin up to get rid of any dirt but other than that, particularly with places like the pod with a treated surface there's plenty of grip.
Saw a turbo'd E36 snap a driveshaft on the line last year
Kos
as i said some thing will break
Is that why they start smoking after five seconds?Kos wrote:unless you sit there for 30 odd seconds they wont heat up, by the time they do they will start tearing to shredsSimon13 wrote:i'm sorry Kos but thats a load of sh!te, warming them up will make a difference to your time
The pressure drop isn't about contact area.
Love from Dave. xxxx
counter the pressure drop and increased footprint with increased drag actually down the strip, it'll sap power
Kos
how's my favoutite c untSimon13 wrote:Is that why they start smoking after five seconds?Kos wrote:unless you sit there for 30 odd seconds they wont heat up, by the time they do they will start tearing to shredsSimon13 wrote:i'm sorry Kos but thats a load of sh!te, warming them up will make a difference to your time
on street tyres it is, on MT's it aint
i'm sure you've seen the way MT crease up on launch, they generate so much heat by the time the finish thier run the preasure goes up
- Homo Hair
on like donkey kong..Davenotouring wrote:No way, Santa Pod it really grippy!
oguz327
- Captain Armco
Anyone else?
maxfield
Maybe my dad will give it a go... can't see the car giving good times mind.
1an
maxfield
Plans for next year.
Still think it will be running under 15 with everything in...
Andy335Touring
It should do that now i'd have thought as it's been modded with cams/ect ?maxfield wrote:
maxfield
It's running 270hp with 199lb/tq but all the power is well over 4k.
Andy335Touring
definately sub 15's, low to mid 14's i'd guess at ?
maxfield
It has big sub box 2 subs, still got a spare in, 1 passenger, probably loads of stuff in boot.
Would I be right in thinking you need a helmet if you're running over 100mph?
Dveight
yeah if you cross the line over 100, ive seen people brake just before to get away with it. for the person that asked bout standard 325i times my standard tech 1 did a 15.8 full to the brim with crap.
Andy335Touring
I think Ian332 was running over 100mph ET and i don't think they made him wear a helmet ?
BTW, your not allowed passengers on the strip, get your dad to empty the boot a bit though
maxfield
Well that's balls...Andy335Touring wrote:BTW, your not allowed passengers on the strip, get your dad to empty the boot a bit though
Looks like I'm wearing the helmet for a couple of runs
Karan
1. Oguz327 - Sterling SE 2.7oguz327 wrote:Anyone else?
2. gareth - 335i touring
3. mattG - touring
4.dips346 - touring (which one )
5. Theo325 - 335i slag
6. Marc
7. Kevin
8. simon13 - 14bhp touring
9. Blingsta
10. Daz tech 1 mk2 Wink hopefully
11. Jhonno - 316i..
14. wilson325i
15. DRIFTBOY - 335i
16. 320touring- 320 and 325i tourings probably
17.Dave- marlboro cheese
18. Karan- iS
i will NOT be doing a burnout as when i do... stuff breaks!
