Project-M45 super charger (developments)
Classic threads, kept forever.
stuartgallafant
Post Thu Feb 01, 2007 11:42 am
sick!!
i'd like to see if i could get my head round it!!
i think i'll go t/b'd up on N/A then whack the supercharger and see what i can do?!
appletree
Post Thu Feb 01, 2007 11:50 am
sounds like a plan :cool: winkeye :twisted:
JK car look very nice love the carbon fibre eveywere :D
appletree
Post Thu Feb 01, 2007 1:32 pm
Made some mounts and fitted the water cooler in the front skirt today
The cooler in place
this is the grill from a 325 sport but the shape made it sit alittle to close to the cooler so i cut it down with a band saw until fitted correctly and let the air flow around the cooler.
cooler grill cut down
and the cooler and the grill in place looking from underneath
schuey
Post Thu Feb 01, 2007 1:50 pm
How clean is your valence???? :eek: :cool:
jk your car is badass!
318 IS. Sold.
appletree
Post Thu Feb 01, 2007 1:53 pm
its had two new wings and a full respary a few months before i tuck it off the road, and then i couldn't put it undercover looking dirty so i gave it a super polish once.... or twice (how sad) :D
jkarran
Post Thu Feb 01, 2007 3:03 pm
Lookin neat Matt, you'd never know it wasn't standard, you'll be leaving some shocked people at the lights with that :cool:
Also see http://www.enginehistory.org/model_engines.htm for an idea on how to cut f***kin hundreds of fins with minimal fuss and indexing, click the Bristol Aquila (the Eagle22 is even more impressive but less relevant). Works well for short items but you might need large dia saws to slit a long bar :?
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
appletree
Post Thu Feb 01, 2007 3:15 pm
what a cool site thats some seriours machining going on. :cool:
next project: making a supercharger......... :D
jkarran
Post Thu Feb 01, 2007 3:42 pm
Thought you might like that :D
jk
stuartgallafant
Post Thu Feb 01, 2007 4:15 pm
looks really good mate, like it was factory!!
jk, what actually is your car?
jkarran
Post Thu Feb 01, 2007 4:48 pm
It's called a Striker and made by Raw Engineering, it used to be a Sylva design but they sold the rights.
Spec is:
Engine - '03 R1, chopped and baffled sump, otherwise standard.
Suspension - Double wishbone all round, no ARB
Dampers - Nitron custom made, inboard at front
Drivetrain - R1 6spd sequential, Quaife reverse transfer box (oil spitting pig), 3.38:1 7" ford diff with Quaife ATB, resiliant tube propshafts, custom lightweight driveshafts.
Brakes - Willwood Powerlite 4pots, Sierra cosworth rear, soon to be swapped for '04 R1 front calipers, 9mm solid disks all round
Weight - Estimated 420Kg wet
jk
gareth
Post Thu Feb 01, 2007 7:24 pm
420kg!!! 8O nice! :D
the dash looks sweet by they way (apart from the wheel :D ). if you finish it off and need some supersexy looking labelling for the buttons, CAD up a design and get someone like tecan ( http://www.tecan.co.uk/core/ ) to make you some up. they can photo etch a design into some stainless steel sheet (like 0.2mm deep matt finish into 0.5mm mirror finish sheet) and cut them out all using a photochemical process. this would look the poodles plumbs!!! one sheet of stainless put through the process will set you back near £100 though so cheaper labels do have their appeal!!!
appletree
Post Thu Feb 01, 2007 7:58 pm
Matts Dad here
Try this for BMW eaton charger on a BMC mini
http://www.mini-performance.co.uk/Sprite%20Page6d.htm goodness knows how the air squeezes down that inlet pipe.
jkarran
Post Fri Feb 02, 2007 10:58 am
LOL to think I was worried mine might have a 1 or 2mm step in it where it meets the SC if I'm not careful.
Progress is slow at the moment. I've made a new bellcrank for the gear shift and located the dump valve (where the battery was :x ) but I'm waiting on a new rosejoint before the bellcrank can be tacked in place and I can start on the inlet properly.
You got anywhere with your inlet duct yet Matt?
My big worry at the moment is management, I'm starting to lean toward a second rail and Megasquirt assuming I can get one addapted for non wasted spark coil on plug ignition :?
jk
appletree
Post Fri Feb 02, 2007 6:22 pm
Ants the man to talk to about the megasquirt, think you might struggle though as i think they use alot of ford parts and the 60 -2 tooth setup.
not much progress on the inlet side of things as ive been strippin the engine and sorting out all the new parts i need plus cleaning and degreasing them all. made a second plate today which will bolt on to the back of my S/C in let to TB plate so that i can graft the bend on to that plate which means i can remove it as and when i need to. it also mean if it doesn't work i have'nt scrapped the first plate which tuck quite along time to make, grinding through stainless with a rotary burr to make the nice curvs of the Inlet/TB joints takes ages.
got the material to make the laminova tubes yesterday so i think the next job will be to make up a drawing to work from as they are going to be reasonably complex in design. :D
jkarran
Post Fri Feb 02, 2007 9:00 pm
Cool, can't wait to see how these coolers look.
I got my bellcrank tacked in place tonight so now I can get on with the inlet ducting. 3 days work and the whole thing has moved ~1/2" hardly seems worth the effort... infact it nearly got binned in disgust when I accidentally tried to weld my finger tip to it :x Ouch.
Making the duct seperate from the plate sounds like a good idea, should make the clay easier to pick out at least.
jk
Ant
Retired Team Member
Retired Team Member
Post Sat Feb 03, 2007 12:07 pm
jk
there is a specific MS for Motorcycle use, its a bit cut down but would run your bike Tb's and Turbo setup quite happily driven by the stock CDI ignition setup.
Nice progress Matt !
jkarran
Post Sun Feb 04, 2007 9:06 pm
Cheers Ant,
I'll look into it, do you know what they call it? My big issue is running coil on plug ignition that isn't wasted spark. Wasted spark is a serious explosion risk if I run an extra injection rail 8O
jk
appletree
Post Sun Feb 04, 2007 9:09 pm
any one got any idea if its ok to run the camcover breather back into my inlet before the Tb so it still under vacume like normal?? just wondered if any of the oil came through if it would damage the S/C or eat the teflon coating on the rotors? :?
Andy335Touring
Post Sun Feb 04, 2007 9:40 pm
Oil catch tank, Rally Design do one for about £45 or so like mine
appletree
Post Sun Feb 04, 2007 9:45 pm
I could get a stainless one made at work its just am gonna be struggling for space and not to keen on having lots of pipes dangling round fast moving pullys/belts, if the worst happens i might get a drain put back to the sump and then a "t" inline to provid the vacume.
or could i put it on the engine side of my manifold and have a non return valve on it??
Demlotcrew
Post Sun Feb 04, 2007 11:03 pm
^ Not sure that would work.
You need a setup like whats found on the S14's
8)
Andrew
jkarran
Post Mon Feb 05, 2007 12:12 pm
Is there some kind of non return valve in that S14 setup to stop crankcase pressure forcing sump oil back up into the inlet or does it just rely on the height difference and the cam cover breather to keep crankcase pressure down?
Looks easy to copy if that's the case :cool:
jk
Demlotcrew
Post Mon Feb 05, 2007 6:50 pm
Im quite sure there is no one way valve.
Andrew
stuartgallafant
Post Mon Feb 05, 2007 8:43 pm
where does pipe number 10 go to? i dont really understand that diagram...
i've always struggled with crankcase and rocker breather stuff....
appletree
Post Mon Feb 05, 2007 9:39 pm
think that must go to the inlet tract so as the the engine causes a vacume it will also make a vacume in the rocker cover???
stuartgallafant
Post Mon Feb 05, 2007 9:40 pm
oh right
Andy335Touring
Post Tue Feb 06, 2007 12:00 am
stuartgallafant wrote:where does pipe number 10 go to?
I think it goes to the bottom of the inlet plenum where oil might collect from the crank case brether fumes, the plenum is at a slight vacuum due to the drag of the air filter.
stuartgallafant
Post Sun Feb 11, 2007 12:32 pm
ive never quite understood oil-catch tanks either!! its something i just cant get my head around!!!
anyone care to explain???
Ant
Retired Team Member
Retired Team Member
Post Sun Feb 11, 2007 12:48 pm
when the engine is under boost, there is positive pressure inside the crankcase which must be vented , otherwise the oil will literally be blown out of the seals.
So the catch tank came into being, the oil vapour will be vented to the tank, the pressure is then vented to atmos through a vent, the oil proper, will be collected @ the bottom of the tank and either returned to sump( need a check valve to return only under low load vac conditions), or manually drained as and when applicable.
no real issue with venting the r/cover breather to atmos only, does the job if you can live with the faint smell of oil when sitting in traffic :?:
stuartgallafant
Post Sun Feb 11, 2007 12:55 pm
ok ant, i think thats helped!!
appletree
Post Sun Feb 11, 2007 7:21 pm
How about this JK they say theres no substitute for cubes
:twisted: http://www.angelfire.com/biz6/stalkerv6/kitcar.html
Turbo-Brown
Boost Junkie
Post Sun Feb 11, 2007 9:10 pm
:lol: wish mine was only a faint stench in traffic :D
My mate's car with a catch tank didn't seem to stink quite so much, guess the fumes condense on the inside of the tank or something.
Why oh why did Buick build that engine?!
You all owe it to yourselves to go out and find a car with a 90degree V6 engine, just so that you can appreciate how rough engines can be! They're almost comically bad!
stuartgallafant
Post Sun Feb 11, 2007 10:35 pm
that stalker thing looks the nuts, but i agree with brown, that engine is pants!! i'd much rather have 'charged rover V8 under there!!!! theres room....
and why is the intake for the charger in the bulk head?!
appletree
Post Tue Feb 13, 2007 8:43 pm
Firstly this is the turbo wastegate i am going to use to regulate boost pressure and protect the charger from back fires.
The top hose connection will have a regulated pressure from the manifold set to Xpsi and the lower connection a second link to th manifold pressure so that when the regulated pressure in the top is lower than the manifold pressure the valve will lift and vent the pressure back to the supercharger inlet.
Also got round to machining up some brackets to support the charger hears the first one in place.
aligned up
With the rose joint in place :D the bolt through is just a tempory mesure till i make a shaft and put some button heads in its place
my washer bottle and IC resivour came today to!! the front half will be for the charger cooling water and the back will be for the windscreen washer water. yes it is a e30 washer bottle from the cars with the headlight wash wipe function :D
gareth
Post Tue Feb 13, 2007 9:01 pm
appletree wrote:vent the pressure back to the supercharger inlet.
would this not heat up the charge exessively? i've not thought out the consiquences of venting to atmosphere though other than sounding like a steam train!
