Steering Guibo Groupbuy: Second Batch SEE NEW THREAD
Dan318-is
Post Sat Mar 22, 2008 5:07 pm
I have been researching into getting some solid steering guibo's made up after this happened to Theo's guibo at bedford not so long back:
Most rubber discs are approaching the 20 year old mark and are the cause of sloppy steering and some serious 'play' in the steering wheel as me and theo found out rather scarily down the a1m.
Now i already have one on my car and am looking to make an exact
replica of the ones pictured below (except the colour). Despite what some may say, i have felt absolutely no change to the comfort or noise/vibration of the car once this mine was fitted; the steering simply had more feel to it and the wheels actually turned left and right even at the slightest turn of the wheel.
This is what they look like:
and when fitted:
The disc is 20mm thick and is a direct replacement for the rubber coupling. As its metal (most likely stainless steel of some sort as it needs to be fairly heat & rust resistant), it needs no heatshield and so this aids clearance for all your m30/m50 guys who are struggling to put shorter racks on your cars.
I am still in the process of getting a quote about getting a batch made. I truly have no idea about cost yet although i am obviously hoping some sort of group discount will be available. As a ROUGH guidance, i am hoping they will be in the £30 region, but certainly shouldn't be any more than £45-50 as this would simply be outrageous and not very cost effective. I would hope to sell around ten sets but obvsiously before i go any further i need to make sure there is interest. So put your name down here even if you MAY be interested and i can proceed from here with what is necessary; if i only have three of four people interested then i will only get that many made (probably).
There will be a prototype run on Theos track slag to ensure fitment, quality and tolerance before i get the rest of the batch made up.
Also just to mention, the original guibo is riveted from the factory. The new guibo is instead bolted in place, but special nuts and bolts are needed from BMW (as seen in the first pic above) which are shouldered and the perfect length. Last time i bought mine they were about £6 delivered, so hardly breaking the bank but worth bearing in mind, as you will need them.
I will upload a CAD drawing of the guibo once the final sizes have been determined. At the moment, sizes are not final; they depend on the trial fitting on Theo's car.
Any questions, feel free!
Regards, dan
1) Theo
2) Zaust (marc)?
3) Tim_s ?
oldroydsr4
Post Sat Mar 22, 2008 5:11 pm
1) Theo
2) Zaust (marc)?
3) Tim_s ?
4) Oldroydsr4 (if price is reasonable, not more than £50)
fuzzy
He who sleeps with "Gingers"
Post Sat Mar 22, 2008 5:21 pm
will these result in a lot more vibration through the steering wheel? or is the difference negligible
jaffro
Post Sat Mar 22, 2008 5:23 pm
[quote="oldroydsr4"]1) Theo
2) Zaust (marc)?
3) Tim_s ?
6)jaffro
Chris-W
Post Sat Mar 22, 2008 5:39 pm
fuzzy wrote:will these result in a lot more vibration through the steering wheel? or is the difference negligible
Dan318-is wrote:Despite what some may say, i have felt absolutely no change to the comfort or noise/vibration of the car once this mine was fitted;
agreen
Post Sat Mar 22, 2008 5:46 pm
1) Theo
2) Zaust (marc)?
3) Tim_s ?
5) Agreen
ROC
Post Sat Mar 22, 2008 6:25 pm
1) Theo
2) Zaust (marc)?
3) Tim_s ?
5) Agreen
6) ROC
Dan, do you have a rough idea of your timescale with these?
Thanks a lot,
Rich.
ed325i
Post Sat Mar 22, 2008 6:27 pm
1) Theo
2) Zaust (marc)?
3) Tim_s ?
5) Agreen
6) ROC
7) ed325i
Dan318-is
Post Sat Mar 22, 2008 6:34 pm
ROC wrote:1) Theo
2) Zaust (marc)?
3) Tim_s ?
5) Agreen
6) ROC
Thanks a lot,
Rich.
I am looking to get them done ASAP. Bank holiday weekend doesnt help, i have sent the drawing of to be checked for quality and if all is good, there may be and up and running prototype, asusming the spec and size is good, on theo's car towards the later end of next week!
Regarding timescale to producation, no ideas as i havent even found a surefire place to make them yet. I would be looking to get the majority of it sorted out before i get back to uni on teh 7th of April.
HTH
agreen
Post Sat Mar 22, 2008 6:43 pm
Nice one dan a nice quick turn around then , if you need a place to make these i have a laser cutting place a few mins from my house where the prices are quite reasonable. If this helps dont want to step on your toes though :D
doughboy
Post Sat Mar 22, 2008 7:15 pm
1) Theo
2) Zaust (marc)?
3) Tim_s ?
5) Agreen
6) ROC
7) ed325i
8 ) doughboy
Ant
Retired Team Member
Retired Team Member
Post Sat Mar 22, 2008 7:31 pm
Sciss Ltd are 5 minutes from Theos House and would water cut those from any material you needed Dan.
Costs would be Very cheap if you made a full batch from a given sheet size dude, put me down for 2 should this go ahead :thumb:
jaffro
Post Sat Mar 22, 2008 7:33 pm
i added my name but its dissapeard :mad:
Theo
Post Sat Mar 22, 2008 7:36 pm
Ant, those are the people I am going to talk to - they did an exhaust flange for me last year and the service was excellent and at a fair price too.
oze30
Post Sat Mar 22, 2008 7:37 pm
Any chance of these to fit an e36/e30 setup?
Theo
Post Sat Mar 22, 2008 7:38 pm
Afraid not Colin, bolt pattern is different.
agreen
Post Sat Mar 22, 2008 7:42 pm
glad to hear there is a good place local to you guys,
Makes things easier .
oze30
Post Sat Mar 22, 2008 7:51 pm
Buggar! Cheers
Theo
Post Sat Mar 22, 2008 7:52 pm
Yeah, they are literally a few minutes away so should get a good turn around.
Just thought I would update the list;
1) Theo
2) Zaust (marc)?
3) Tim_s ?
5) Agreen
6) ROC
7) ed325i
8 ) doughboy
9) jaffro
10)Ant (x2)
Karan
Post Sat Mar 22, 2008 7:54 pm
1) Theo
2) Zaust (marc)?
3) Tim_s ?
5) Agreen
6) ROC
7) ed325i
8 ) doughboy
9) jaffro
10)Ant (x2)
11)Karan
come on lads hurry up :cool:
shorty73
Post Sat Mar 22, 2008 10:03 pm
) Theo
2) Zaust (marc)?
3) Tim_s ?
5) Agreen
6) ROC
7) ed325i
8 ) doughboy
9) jaffro
10)Ant (x2)
11)Karan
12)Shorty73
You can stick me down for one. :wink:
agreen
Post Sat Mar 22, 2008 10:12 pm
1) Theo
2) Zaust (marc)?
3) Tim_s ?
5) Agreen
6) ROC
7) ed325i
8 ) doughboy
9) jaffro
10)Ant (x2)
11)Karan
12)shorty73
there you go mate
shorty73
Post Sat Mar 22, 2008 10:17 pm
Nice one Arron. I'm f$£&ing useless at this stuff!
agreen
Post Sat Mar 22, 2008 10:19 pm
lool i am usless at collecting helmets loool :o: need to meet so i can get that off you dude let me know when your next around maybe meet at nigels if your over his way and you can see the itb's on the car 8)
shorty73
Post Sat Mar 22, 2008 10:27 pm
yes mate no probs. Not sure when I'll next be Bury Bound but I'll let you know.
agreen
Post Sat Mar 22, 2008 10:30 pm
collio cheers craig , sorry for spam dan 8)
Turbo-Brown
Boost Junkie
Post Sat Mar 22, 2008 11:12 pm
When you install these, it's worth replacing the pinch bolts (or at the very least the deformed nuts) on the UJs too.
I didn't and one of mine rattled itself loose which could've been nasty!
Definately a worthwhile mod and as Dan says it doesn't cause any discomfort through the steering wheel.
Yaninnya
Post Sun Mar 23, 2008 12:06 am
Dan318-is wrote:Despite what some may say, i have felt absolutely no change to the comfort or noise/vibration of the car once this mine was fitted; the steering simply had more feel to it and the wheels actually turned left and right even at the slightest turn of the wheel.
I can confirm it. I have a home made version in my car and can't notice any increase of noise or vibrations. And the steering feel is very good.
Dan318-is wrote:As its metal (most likely stainless steel of some sort as it needs to be fairly heat & rust resistant), it needs no heatshield and so this aids clearance for all your m30/m50 guys who are struggling to put shorter racks on your cars.
Is it from Muzzimotorsport? They are selling DTM copy and it is alloy made. Can you make it anodised alloy?
Dan318-is wrote:I am still in the process of getting a quote about getting a batch made. I truly have no idea about cost yet although i am obviously hoping some sort of group discount will be available. As a ROUGH guidance, i am hoping they will be in the £30 region, but certainly shouldn't be any more than £45-50 as this would simply be outrageous and not very cost effective.
Muzzimotorsport is selling alloy ones for € 57.00, so if it will be too costly, we can make a group buy, I think.
Just my 2p.
Jan
Karan
Post Sun Mar 23, 2008 10:30 am
oops just realised it wont work on mine because of the 30/36 combo
Dan318-is
Post Sun Mar 23, 2008 11:35 am
Yan,
yes mine is from muzzi & i also thought it was annodized alloy. When i bought mine some time back, however, it was only ┚¬35 , not ┚¬57.
Muzzi is a good second idea, didnt think of that!
1) Theo
2) Zaust (marc)?
3) Tim_s ?
5) Agreen
6) ROC
7) ed325i
8 ) doughboy
9) jaffro
10)Ant (x2)
11)shorty73
Yaninnya
Post Sun Mar 23, 2008 2:00 pm
Dan,
I want to buy an alloy one, so if you are considering that option, you can count me as well.
Jan
blitz877
AKA ajm-e30
Post Sun Mar 23, 2008 2:22 pm
Dan318-is wrote: il have one too please dan
1) Theo
2) Zaust (marc)?
3) Tim_s ?
5) Agreen
6) ROC
7) ed325i
8 ) doughboy
9) jaffro
10)Ant (x2)
11)shorty73
12)blitz877
Dan318-is
Post Sun Mar 23, 2008 6:29 pm
Spoke to simon today who says his uncle may be able to knock them up in alloy! Going to send the drawing out and get a few quotes in the week.
agreen
Post Sun Mar 23, 2008 6:53 pm
Good work dan .
Nice one for keeping this one on the boil. 8)
Yaninnya
Post Mon Mar 24, 2008 10:53 am
Dan318-is wrote:Spoke to simon today who says his uncle may be able to knock them up in alloy! Going to send the drawing out and get a few quotes in the week.
That will be perfect for me. Hope that the cost will be acceptable.
Jan
