ABS Bypass
Timbopbmw
Post Sat Nov 17, 2007 12:32 pm
As i cant run the ABS in pbmw and it doesnt work on my car anyway is the easiest way do bypass it changing the brake lines and running them straight to the master cylinder rather than going through the ABS unit?
cheers
march109
Post Sat Nov 17, 2007 12:36 pm
well the easiest way would be to remove the fuse, but at least your way would allow you to also remove the system and save some weight.
UweM3
Post Sat Nov 17, 2007 5:57 pm
Timbopbmw wrote:As i cant run the ABS in pbmw and it doesnt work on my car anyway is the easiest way do bypass it changing the brake lines and running them straight to the master cylinder rather than going through the ABS unit?
cheers
I have removed my ABS and run lines direct to the MC. Quite a bit of weight, the wiring alone is a chunk!
agreen
Post Sat Nov 17, 2007 6:07 pm
i have no abs on my 318is also !
dont need it :mad: :P
shorty73
Post Mon Nov 19, 2007 11:28 am
cheers
Any chance of a photo? I'm just about to do this and mate it up with a bigger bore Master cylinder and a bit of help would be great.
Have you used the exsisting lines or new ones?
Timbopbmw
Post Wed Nov 21, 2007 5:25 pm
is there only one master cylinder for abs and non abs?
is there some sort of compenstor for the rear brakes?
cheers
shorty73
Post Fri Nov 23, 2007 12:54 am
Not sure mate. Just saw this and it looked to answer my needs.
http://e30m3performance.com/installs/in ... c/25mc.htm
ATE do a master cylinder for a 740i which is mean't to go straight in. Eurocarparts have them in stock. I'm hoping to get mine next week from somewhere else so I will put up some pics once it's in if you want?
Timbopbmw
Post Fri Nov 23, 2007 4:01 pm
i had a look at a local 320 yesterday,it was non abs and had the same master cylinder,but mine(abs)has a blank underneath.Now it looks very simple,just a case of making up the new pipe.
thanks for all your help
Tim
