Battery cut-off switch
Theo
Post Fri Oct 26, 2007 12:43 pm
I've been given a simple battery cut off switch like this:
How do you fit one of these to an E30 with the battery in the boot?
Thanks,
Theo
Chris-W
Post Fri Oct 26, 2007 12:46 pm
Could you not fit it to the remote positive terminal under the bonnet?
Theo
Post Fri Oct 26, 2007 12:53 pm
Ideally, I want to have the switch mounted in the car in place of the clock, if this is possible?
gareth
Post Fri Oct 26, 2007 2:13 pm
it's possible but you'll need to re-route the battery cable to the switch and make up a new length to run to the front which will never be fun! could you not mount it on the floor, somewhere on the existing cable run?
i fitted one on our mini, under the rear seat / heelboard area which also doubled as a nice hidden immobiliser.
JimmyC
Post Fri Oct 26, 2007 3:56 pm
I had mne where the clock was before upgrading to an electric isolator
No pic, but if its not the FIA ones then dont use it when the engines running or you will fry the alternator
The FIA ones wire through the live, the ignition and the alternator
The others can just run through the earth
JimmyC
Ah the pic wasn't working when I wrote the above, just run through the earth
