i am buying a saftey devices for my 318is track and road car
it took numorious threads and many hard thinking sesions but the way i look at it and belive me i have resereched this is as follows
an omp cage does NOT come painted
Omp cages do NOT have demovable door bars they are weld in and this means it would be dificult to get the cage out again after fitting if say you were gonna upgrade to an m3 later on in life
Omp cages do NOT have a cross over in the rear section so the harness can not be secured in the right posision IMO
omp cages have smaller diameter tubing than the sd cages omp look skinny and weak althought they are probally not next to a sd cage
and the final thing is like i say a sd cage what £700 and omp £ 400 around so
£400 for the cage 100 quid for materials to paint it, 100 quid to weld the doorbars in perhaps?,and the cages some of it need to be painted in the car as the door bars like i say need to be welded in and if there are no more cost which there WILL be unless you fit the whole thing yourself then the sd cage is almost the same pri ce as the omp and imo not worth it go for omp otherwise you are gonna be sitting at the side of the track, or whatever , and someone in there 318isis gonna pull up next to you , witha sd cage you are gonna see the ovrsized tubing and powder coated goodness and kick youself because you did not just wait and save
i hoipe this help and all these factors are why i am in the processs of getting a sd cage (should order on friday )
like i say the above views are IMHO and not the views of everyone else so no quotes saying it does not cost this much etc please thanks and i hope you get the right cage for your needs and it is hastel free
Agreen
