in the process of trying to sort a diff out. im looking for some information, what sort of power are the e30 diffs good for? is there a different between small and large case?
i need something that will not break with lots of power, but dont want to use a m5 as there very heavy.
and can the diffs be rebuilt to a 2way drift style diff, what types do the drifters on here use. thanks.
LSD mods
I can't specifically answer those questions but you might find this thread interesting / useful.
http://www.e30zone.net/modules.php?name ... hlight=cwp
Hiya, i've machined several sets of ramp angles in lsd out of 325's i used a ford clutch pack in mine the ramp angles made it lock up superbly well too. if you're interested i could be tempted to machine yours.
Kev
Kev
- GermanGorilla
Hi,
Kevo- Can you please PM me a price for the following if your
interested -
E30 Med / Large Case Diff 3.73 LSD.
Remove CW/P, and standard dual BMW Clutch Plates.
Alter and re- harden the Ramp Angles to 70-30.
Fit the Ford Atlas 4 clutch pack/ set to 40% lock up
Remove the timing Triggers.
Reset, and then re-assemble Diff.
Wait to hear from you, hopefully.
Regards,
The Gorilla.
interested -
Regards,
The Gorilla.
CraigG
- Contact:
if your wanting a decent LSD, ditch the shitty OEM style and get a plate style locker. TranX or Gripper. i suppose an quaife ATB would also be mucho better than standard, albeit not as good as a plate type.
what about those obx ones that are or flee bay from the states, are they any good or are they just cheap chinese rubbish.
kevo could i also have a price on that diff rebiuld as well, as now very interested. sounds like a good set up.
