LIGHTWEIGHT EXHAUST 325i ??
doolie
Post Thu Apr 05, 2007 10:47 am
I'm looking for a lightweight exhaust system (single pipe maybe?) for my 325i. The events I enter restrict us to the standard manifold, but the remainder of the system is free. Does anyone have a similar set up on their track car?
DJ-325I
Post Thu Apr 05, 2007 7:39 pm
build your own system? could be cheaper..... jetex seem quite a good company for making your own exhaust.
Taffy
Post Sun Apr 08, 2007 1:22 pm
BTB make the best exhaust for a 325
please contact admin with regard to sig
skidmark
Post Wed Aug 29, 2007 1:52 am
If you can weld ..... try getting a second front box (with entry and exit pipes straight through) and replace the big heavy (NOT straight through) rear box with it. Use the straps and mounting system off the old box (suitably cut and modified and welded on) to mount the new system.
I did this and it was a little bit noisier but still within the 98 decibel limit at Donington (one of the toughest) and because the box is smaller and lighter, getting the mounting rubbers on was easier, too.
I had the standard cast manifold and front pipes then ......... but I am half way through putting on my new BTB 6 branch :mad: ....... for the moment I will use the two front box system (as above). I'm expecting it to be a little noisier but hopefully quite purposeful and still legal for track days.
JCB
Post Thu Aug 30, 2007 12:11 am
btb - expensive but very very good and very quiet
JimmyC
Post Thu Aug 30, 2007 10:37 am
The Miltek systems are VERY light, the 320 system designed initially for PBMW wont restrict a 325, Niggy runs it on his 2.7 and is competitive against some of the m3's!!
dannyboy759
Post Sun Sep 02, 2007 11:20 am
Superspint i think do a groupA type system but the one I had on my M3 was very loud and was not street legal so I dont know what rules you have and what db limit
