bucket seats
salami
Sun Dec 10, 2006 2:11 pm
hi just got a set of motorqaulity bucket seats off flea bay to go into my track car.
can anyone point me in the right direction as to correctly fit these,
they have rigid mounts, can i just drill new holes and bolt them to the floor?
Nelly
Gumbo
Gumbo
Sun Dec 10, 2006 10:22 pm
Yes you can but, i'd reinforce the mounts ie; 2x pieces of flat 5mm steel with a hole drilled in them so the new bolt can pass through all,place on each side of the re-drilled holes so the mounting point doesn't rip out the floor if you had a nasty at any time.
Neil.
"I F**KING LOVE YOU GUMBO"
agent006
Mon Dec 11, 2006 12:13 am
Nelly wrote:i'd reinforce the mounts
You'll have to do the same with the new harness mounts too.
salami
Mon Dec 11, 2006 9:28 am
can i fit the harnessess anywhere i want or are there certain places i must put them(does anyone have pics of them in there car?)
thanks
agent006
Mon Dec 11, 2006 4:31 pm
Mine are mounted into the floor for the lap belt (using seatbelt mount on the outside and new plated mount on the tunnel side). Shoulder belts are mounted on the rear shelf.
JimmyC
Mon Dec 11, 2006 4:42 pm
agent006 wrote:Mine are mounted into the floor for the lap belt (using seatbelt mount on the outside and new plated mount on the tunnel side). Shoulder belts are mounted on the rear shelf.
There was a big smash at Donny (I think) where a guy had used the rear shelf, it was very obvious the rear shelf is a very weak place to mount harnesses
I have seen them mounted in the rear seat belt mounts but you are not meant to have that angle on the harness either
With out a cage and a harness bar, you may be safer with 3 point belts and a glock (or what ever its called)
Just my 2p
agent006
Mon Dec 11, 2006 4:54 pm
JimmyC wrote:With out a cage and a harness bar, you may be safer with 3 point belts and a glock (or what ever its called)
True. The belt buckle goes with the seat though. Car's not in use now until it gets a cage (and an engine that works).
JimmyC
Mon Dec 11, 2006 4:58 pm
Ah good point, hadn't thought that through had I :lol:
salami
Mon Dec 11, 2006 7:04 pm
could i go through the rear seat floor then through a bar of sumsort?
the harness is a four point
thanks
