Auto's on track
califunky
Sat Nov 11, 2006 8:53 am
Has anyone had any experience of the auto box on track?
I cannot drive a manual but love the track so am just wondering what its like.
Whats the kickdown like? Does the box have a habit of changing gear mid corner? Is the box quite predictable?
Cheers for the help in advance.
Davenotouring
Sat Nov 11, 2006 10:06 am
You should be ok, from memory a guy under the name of Monsport has an Auto 325i Sport which he takes on track.
No real problem with it. Go for it!
BMW 328i Cab - Daily Slag
Nelly
Gumbo
Gumbo
Thu Nov 16, 2006 6:42 pm
Correct Dave, it was Monsport.
Auto should be fine, just drive it through the gear box manually 1 2 3 D
"I F**KING LOVE YOU GUMBO"
tomtomiS
Fri Nov 24, 2006 12:06 am
Nelly wrote:Correct Dave, it was Monsport.
can u drive it up and down the box or would that be a box killer?
agent006
Fri Nov 24, 2006 10:31 pm
califunky wrote:I cannot drive a manual
Then you'll be fine. If i drove an auto on track i'd have gone insane by the end of the first lap, but that's because i know what a manual is like to drive. If you've never known it then you'll be none the wiser.
320Touring
Sat Nov 25, 2006 1:04 pm
auto's are ace on a track, or doing point to point.
gives you the ability to work on hitting the apex and carrying speed through the corner- all without worrying about the gear, engine revs etc.
you can add that in at a later date, once you have built up confidence and ability :cool:
rtdracer
Mon Jan 01, 2007 8:01 pm
320Touring wrote:auto's are ace on a track, or doing point to point.
Hmmm - have to disagree. It's fine if you're pootling around, but if you're 'poised on a knife-edge of grip' and it kicks down a cog, I think you'd exit stage left PDQ. 8O
m-dtech
Unapproved Trader caution
Wed Jan 03, 2007 12:46 am
driving on a track is about pushing you and your car to the limit.
if its switchable sports mode it wont kick down in 1,2 or 3
have fun, but watch that the gearbox fluids dont heat up too much.
k10
Sat Mar 24, 2007 7:51 am
Auto, zzzzzzzzzz
ed325i
Sat Mar 24, 2007 6:59 pm
And I have just changed mine to manual :roll:
