interior weight
dje30
So I've removed my interior this weekend so
Seats
Carpet
Roof liner
All plastics
Glove box
Centre console
Litterally everything but the dash
A hefty amount of wiring from a toad alarm
So my first question is how much does all that interior weight roughly?
And has anyone completely removed the sun roof? How much did this weight?
Dave
Seats
Carpet
Roof liner
All plastics
Glove box
Centre console
Dave
roadrally_nova
i have removed the sunroof on mine must be 25kg with everything at least.
i would also remove the sound deadening as well best way is use a hot air gun peels of easy then theres a lot of weight in that as well.
I have also removed the back rest and a lot of the parcel shelf as well another 25kg there but would sugest a rear strut brace if doing that
Demlotcrew
Wow 25kg for the sunroof parts? Thats at least double what I thought it might be.
Andrew
Andrew
roadrally_nova
thats including the sun roof itself water pipes winders and every piece of metal joined to it
Demlotcrew
A sunroof panel comes in at 5.2kg, the difference between a sunroof and non sunroof shell is 5kg, thats not including the pipes or motor/rails/windings, which at a push might come in at say 2kg.
Thats no where near 25kg!
Demlotcrew
Electric motor is 800grams, rails are 200 grams and the cable mechanism plate is only 500grams = 1.7kg.
10kg max inc the roof tray and gutting the panel
verde
Carpets heavy as hell. Car raised when I took it out. It must be 20_25 kg
Raise hell praise Dale.
roadrally_nova
i must apologise i meant 25kg with the back rest as well . just read what ive typed been up all night with the little one teething
Demlotcrew
When its wet, it will easily be 25kg+ dry its half that.verde wrote:Carpets heavy as hell. Car raised when I took it out. It must be 20_25 kg
kod81
I know it's an old thread but I thought I'll post my feedback in case anyway was to come across it (like me).
I've recently removed the interior parts from my 318i and I put each one on a scale so here it goes:
rear seat: 13.5kg
rear shelf: 2.8kg
rear seat belts: 2.6kg
spare wheel: 15.9kg
central console (the part around the handbrake): 0.3kg
rear quater trims: 2.8kg
boot lining: 5.3kg
floor mats: 3kg
those plastic covers on A.B,C poles: 0.2kg
hand grips and speaker covers: 0.8kg
floor carpet: 8.7kg
front speakers: 0.6kg
roof lining: 2kg
front seats drivers:17.7kg
front seat passangers: 17.4kg
sunroof: 14.7kg
total: 111.7kg
I've also removed the glovebox and other bits and pieces but forgot to wieght them.
rear seat: 13.5kg
rear shelf: 2.8kg
spare wheel: 15.9kg
boot lining: 5.3kg
floor mats: 3kg
floor carpet: 8.7kg
roof lining: 2kg
sunroof: 14.7kg
total: 111.7kg
Demlotcrew
milescook
Sound deadening and heat proofing,another 5-10kg
Roll cage....
Roll cage....
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
kod81
Sound and heat proofing yes. I've removed most of it and so far I've got 8.6kg out of it. That's all from under the rear seats, including the inside of right quater panel (right didn't have any) and from under the front seats. All that's left is the two footwells but it will go soon.
BTW.. I had to replace the two drain plugs from where the fronts seats are and the proofing was as they have rusted through. Very cheap part from the dealer. About £5.
Demlotcrew
The front doors also have sound deadening in them.
