Gaz coilover adjustable front topmount
tomson
Post Sun May 15, 2011 2:38 pm
Are these available seperately does anyonw know and if so where can I buy some ?
Gaz's website does not tell me if they are available seperately :?
BadDave
Post Sun May 15, 2011 3:28 pm
PM'd Tom
tomson
Post Sun May 15, 2011 3:32 pm
Uploaded with ImageShack.us
These are what I have but I believe there is a piece missing Dave ? I wish I'd realised when I bought them...
BadDave
Post Sun May 15, 2011 3:38 pm
Roller bearing and retaining clip Tom?
tomson
Post Sun May 15, 2011 3:51 pm
TBH I'm unsure, I can only get 2 holes to line up on the strut tower, not all 3 as per this photo -
I saw these below mounts in the RPM section and it made me realise why they dont fit as there is a piece missing, I think !
http://www.e30zone.net/modules.php?name ... c&t=146963
Cant remember the zoner I bought them from to ask him if he still has the bits im missing :cry:
SteMarsden
Post Tue May 17, 2011 12:10 pm
I had these before I fitted the RPM topmounts.
The aluminium eccentric part fits at the inside of the turret top, and you have to elongate 2 of the 3 mounting holes to get them to fit.
You dont need the original rubber topmount (which you may have just shown to illustrate)
HTH.
Ste.
BMW E30 318i ex PBMWC track car
2011 VW Passat Est
RPM
Post Tue May 31, 2011 8:21 am
tomson wrote:TBH I'm unsure, I can only get 2 holes to line up on the strut tower, not all 3 as per this photo -
Hi Tom
Ours are a completely different design to the ones you have.
Yours are a one piece mount that rotates to give you adjustment, unfortunately you can adjust camber and castor independantly and the adjustment is limited.
I can supply spares for your mounts though if you do need anything.
Or better still upgrade to ours ;)
Jimmy
Black_Potato
Post Wed Jun 01, 2011 5:15 pm
Yeah.. buy some off Jimmy and flog your others :)
tomson
Post Wed Jun 01, 2011 10:05 pm
Thanks for the advise guys.
Am I actually missing anything from my current topmount ? I cant believe a company like Gaz makes the mounts like this and expect you to elongate the turrent holes ?? :?
SHAZ325iSPORT
Post Wed Jun 01, 2011 10:10 pm
im using the ones pictured on my gaz coilovers,i had to drill another holeout aswell because only 2 bolts lined up.
worked well with my setup.
