Powerflex eccentric wishbone bush !
Rallyprep_UK
formerly Driftnething
Post Tue Oct 26, 2010 8:53 pm
My bushes turned up today and I am looking at them and thinking - why are they two piece items and not like the standard bmw offset wishbone bushes ?!!?!
My point being = Surely the inner part which goes onto the end of the wishbone will pivot inside the outer as the wheel moves up and down...
I am guessing it does not move enough to matter, but - whats wrong with just making a 1 piece bush ?
Also they do not look like they are going to give a huge amount of offset but I am led to believe that when combined with E36 3.2 hubs/wishbones the wheel should sit forward enough not to be a problem on the e30 ?.
I am tempted to get some treehouse racing style mounts or machine down some hockey pucks on a lathe and try to make some one piece bushes and see how far offset I can make the hole for the wishbone get it to move forward with the hope of not having to source the costly 3.2 wisbones...
Any advice or input would be greatly appreciated as I am sure I am not the first person to think about this and my searching is just failing :cry:
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
Rallyprep_UK
Post Tue Oct 26, 2010 8:55 pm
If it makes any difference by the way, I have Apex racing coilovers from an E36 3.2, standard hubs and wishbones from the same vehicle and RPM fully adjustable top mounts...
Post Tue Oct 26, 2010 9:17 pm
Why not just use the BMW eccentric bushes Will? Solid rubber, less bulky than the powerflex and only £30 odd.
Do you have the Evo wishbones or the earlier 3.0 litre jobs? As I understand it you have to use the Evo wishbones
Rallyprep_UK
Post Tue Oct 26, 2010 9:50 pm
I was hoping to have something a bit harder than the BMW ones, hoping to increase steering accuracy (not something for the road cars as I bet noise and vibration are vastly increased).
But basically if I can eradicate the need for evo wishbones (and have the bonus of a harder material) that would be great.
As I am sure you know - good second hand evo wishbones are few and far between and not cheap whereas the standard E30/6 ones are 10 to the dozen and picked up for a few quid !
I am going to give it a bash as soon as I can find somebody local who is willing to let me loose on their lathe !!!
So basically...
E36 M3 wishbones - approx 100-125/pair used and over £100 eac new iirc...
Offset BMW bushes - £30 ? ish (im not sure on these) or Polyflex type offset bushes - £45
verses
E30/36 wishbones - £20+ vat
hockey pucks - £4
Beer money to borrow lathe £10
Effort - £free lol
can you see what I am thinking ?
plus I have another E30 project now and another complete e36ti trailing arm/rear beam setup kicking around along with various wishbones and some hockey pucks and so on...
That £175 could be money towards rubber haha winkeye
Rallyprep_UK
Post Tue Oct 26, 2010 10:02 pm
Good news, after a facebook request for the use of a lathe I have 2 possibilities already :D
I will update with my findings and experiments as and when...
Post Wed Oct 27, 2010 8:54 am
I cant see how you will move the arm forwards enough by machining a new rear bush, you would have to redesign the lollypop mount IMO
Id probably just buy the wishbones to save all the messing 8)
Post Wed Oct 27, 2010 9:49 am
There is nothing wrong with the 2 piece powerflex bush.. No extra noise or vibration
You need the Evo wishbones with offset bushes, unless you are going to completely redesign the rear bush out of metal and spherical bearing..
N00b
Post Wed Oct 27, 2010 9:14 pm
Driftnething wrote:My bushes turned up today and I am looking at them and thinking - why are they two piece items and not like the standard bmw offset wishbone bushes ?!!?!
Because you'd destroy them trying to fit them if they were one piece like the rubber part.
Barton
Post Wed Oct 27, 2010 9:46 pm
does anyone have a pic of how these are supposed to look once fitted? thanks
i.e what way round the bushes push in, and where the position of the eccentric should be
rix313
Post Wed Oct 27, 2010 10:06 pm
Barton wrote:does anyone have a pic of how these are supposed to look once fitted? thanks
Just posted this in tech help too, hope it helps:
This is the N/S bush. Basicaly you want the wishbone 'pin' as close to the mounting point which bolts to the car as possible.
Barton
Post Wed Oct 27, 2010 10:15 pm
just seen the other thread, thanks, very useful
