Spoilers.... Noticed Any Difference
George_Of_The_Jungle
Post Thu Jul 08, 2010 10:16 pm
Just wondering if anyone has noticed any difference in performance between spoilers on the track?
I'm guessing the smallest spoiler helps the air break from from the back of the car, but how much turbulence does the angle of the rear window create? I'm also guessing the tech 2 spoiler doesn't really have any extra benefit, apart from a better weight distribution.
Reason I ask: I have just come into a small amount of inheritance, and i'm either going to get a 318 and enter the production BMW series that so many of you are part of. Or start building a twin seater (like a radical SR4) I have designed from scratch.
Post Fri Jul 09, 2010 12:09 am
The M technic 2 kit and Alpina spoilers were developed in a wind tunnel.
harry_p
Post Fri Jul 09, 2010 12:29 am
to do what?
reduce drag? reduce lift? create down force? a combination of the above?
cheers,
harry
Post Fri Jul 09, 2010 6:01 am
abit of both, but mainly reduced drag
RPM
Post Fri Jul 09, 2010 10:53 am
If your asking for a PBMW car, you can only run the heck spolier (part number in the regs)
Post Fri Jul 09, 2010 11:40 am
sort of asking for general knowledge, but that is gd to know thanks.
Petrolthreads
Post Fri Jul 09, 2010 2:02 pm
I was wondering the same, no help I know because I am spoiler less at the moment
Fushion_Julz
Post Fri Jul 09, 2010 4:02 pm
I've tried different spoilers on different cars...
I used to race a 2002ti....I had 2 bootlids (both fibreglass) one flat and one with the turbo spoiler profile...
It was purely a racecar...
The flat bootlid made the car feel loose at the back at high speeds (Revett straight, for example), but at lower speeds there was no discernable difference.
My M3 started with a standard spoiler and I have now got that an an Evo Sport replica with road going Gurney...The Gurney flap makes a fairly big difference...again only at higher speeds, but at full extension it takes approx 350rpm off the top speed down Silverstone Hanger straight compared to it fully retracted...There is no difference between the retracted flap and a standard M3 spoiler...
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Post Fri Jul 09, 2010 5:13 pm
Fushion_Julz wrote:I've tried different spoilers on different cars...
Cheers for the info. Did the Gurney come with the rep spoiler or did you create it your self?
rix313
Post Tue Jul 13, 2010 6:55 pm
Technicaly they are 'wings' as they produce down force. Spoilers are found on hatch backs and they remove the vacuum which forms behind the boot causing drag (please correct me if I'm wrong). You can buy adjustable M3 rear wings for £150 or so IIRC.
