Bonnet vents?????
bumhole
Mon Feb 15, 2010 8:49 pm
Been mulling over the idea of cutting a bonnet vent in over the area where my cone filter is............... what do ya think??
possibly one like this:
They are £30+postage for a pair
Is there any advantage to the idea?
Andye
Tue Feb 16, 2010 9:04 am
Looks like a 3dr sierra cosworth vent. Most bonnet vents are from turbo applications and are for getting hot air out rather than cold air in. You're probably better running a cold air pipe from the front of your car to the cone? I've taken the head light out before on track days as well to help?
bumhole
Tue Feb 16, 2010 9:40 am
Errado Andye, they are off a cossie. I was going to put the vent upside down so the air scooped in rather than out. I just can't be bothered to faff with the headlight so I thought this may be an alternative.
caneswell
Tue Feb 16, 2010 1:41 pm
Air doesn't really scoop in the way you are thinking, unless you have a massive thing stuck out in the air stream. Which ever way round you mount it the low pressure air over the bonnet will cause the higher pressure air under it to come out that way. Does that make sense?
GeoffBob
Forced Induction Specialist
Tue Feb 16, 2010 2:25 pm
caneswell wrote:Does that make sense?
Yes it does. Another way to put it is that air always flows from high to low pressure, regardless of which way around you mount the vent.
bumhole
Tue Feb 16, 2010 2:27 pm
errr..... That means it won't work as I intend will it?
damn........... :(
UweM3
Tue Feb 16, 2010 2:28 pm
I was under the impression that bonnet vents also reduce front lift (if large enough) by letting trapped air out of the engine bay?
bumhole
Tue Feb 16, 2010 2:53 pm
What about this one:
sorry to be silly :roll:
toby
Tue Feb 16, 2010 2:56 pm
I think you should get a bonnet vent shaped like a bumhole.
Sorry to be sillier...
bumhole
Tue Feb 16, 2010 3:22 pm
I am so bored at work i'm actually looking for pictures of anus shaped bonnet vents.
Didn't find any but did find this......
toby
Tue Feb 16, 2010 4:17 pm
That's funny! I'm so bored, I was looking too but got some nasty results with 'safe search' turned off... :eek:
