Lots of talk here recently of the benefits of asjustable top mounts.
Question is, how easy are they to fit?
Fitting Adjustable Strut tops
Theo
Same proceedure as fitting standard top mounts. You need to remove the front leg, take off the old top mount and replace with an adjustable type.
RPM
Very simple (as above), only a benefit if you use them as intended, ie to adjust the setup
http://www.raceperformancemodified.com/ ... mounts.asp
agent006
"Remove the front leg" sounds quite involved. Do I need spring compressors?
Theo
You should use them, but I don't bother. I just use a buzz gun on the top nut and the spring pops off with minimal fuss.
agent006
Cool. Any idea how long it would take a competent (i.e. someone i was paying to do it) mechanic?
Theo
I never pay people to do work on my cars so not really sure. It's do-able in an hour, certainly wouldn't take longer than 2.
agent006
Brill, thanks. Looks like I'll get it done for me. If it was a fiddly 3 or 4 hour job it'd be worth having a go at it myself.
Conan
once there fitted how easy are they to adjust?
'91 Sterling Silver e30 320i SE
'96 Avus Blue e34 525i Sport
'92 Alpine White e30 318iS Touring
'86 Alpine White e28 M5 (008/187)
'02 Titan Silver e39 530d Sport Touring
'54 Cosmos Black e61 535d MSport Touring
'07 Sapphire Black e61 M5 Touring
RPM
Conan
And are there clear 'notches' or markers to show what your doing to the camber and castor?
