Sump baffles
rix313
Post Tue Dec 15, 2009 8:12 pm
I've designed a baffle system for my sump.
What I want to know is what thickness material should I use?
3mm seems a little extreme and want to make sure 2mm will be enough.
Just can't make my mind up.
UweM3
Post Tue Dec 15, 2009 8:16 pm
without pictures it's hard to advise.
-- bolted or welded?
-- Aluminium or steel?
rix313
Post Tue Dec 15, 2009 9:07 pm
Hi Uwe,
Will be aluminium and welded in.
UweM3
Post Tue Dec 15, 2009 9:24 pm
given the low weight of aluminium I don't think it matters if you use 2 or 3mm. If you keep it close to the sumps wall thickness, welding will be easier. suggest 3mm.
rix313
Post Tue Dec 15, 2009 9:29 pm
UweM3 wrote:If you keep it close to the sumps wall thickness, welding will be easier. suggest 3mm.
Good point to consider that cheers :)
