Filling rubber bushes.
- Homo Hair
Fitting some new subframe bushes which have nice big holes in them.. What could be used to fill the holes to stiffen them up a little?
Theo
stuff what is strong and hard innit.
- Homo Hair
Bit of 2x4?
UweM3
mastik which is used to bond front screen in. Or SIKAFLEX
- Homo Hair
Awesome, cheers Uwe
d6dph
Tigerseal does a good job on landrovers used off road from what I have been told.
- Homo Hair
Need to go to Hellfrauds anyway for some Hammershite, so will have a looksee what I can find..
mike_sayer
We've been through a couple of tubes of Tigerseal - it's awesome stuff, sticks like sh*t to a blanket but remains flexible. Don't get it anywhere near the bodywork though
"And if you are clinically insane, by which I mean you wake up in the morning and think you are an onion, here's your car." - Clarkson
d6dph
Fantastic stuff isn't it! A mate of mine makes car transporters and the stick fecking great sheets of metal on a vertical surface with it!
Dan If you don't have any joy, I think I have some at work if you need me to pick up a tube.
- Homo Hair
Well i'm not trying to stick the car to the side of any building.. The road would be handy though
Sawyer_E30
Can't you get that liquid poly stuff?
Some bloke over the water did that and there's a guide for it somewhere...
Hang on!
Hang on!
E30: The only E-number you should be concerned about
nickso
- Location: Go do that voodoo that you do so welllllllll!!
doesnt somebody make (or made) plastic inserts that you push into the holes. was possibly a group buy and was possibly american.
'88 e30 328i M52 track bint.
kimbo
Dont want to state the glaringly obvious, but shouldn't the bushes have the right sized holes in them?
Or am I being daft!
Kim
Or am I being daft!
Kim
oze30
There are voids around the actual sleeved rubber bit. 2 smiley looking faces which you fill.
kimbo
That explains it - I thought I was being daft.
Silicone is the thing then, I would say.
Kim.
Kim.
handpaper
Someone on e30tech.com had some made up a few years ago; I can't find the thread but THIS is pretty much what was done.nickso wrote:doesnt somebody make (or made) plastic inserts that you push into the holes. was possibly a group buy and was possibly american.
nickso
thats the one.handpaper wrote:Someone on e30tech.com had some made up a few years ago; I can't find the thread but THIS is pretty much what was done.nickso wrote:doesnt somebody make (or made) plastic inserts that you push into the holes. was possibly a group buy and was possibly american.
GeoffBob
- Forced Induction Specialist
Which bushes are we talking about gents? The ones that join the rear sub-frame to the body?
I turn my own on the lathe from a length of polyurethane round bar. You can also use Nylon, Vesconite or Tufnol depending on the hardness of the ride you want. I press all the bits back together with an hydraulic press. They are good for the track, but the stiffer and/or weaker the material you choose the quicker they wear out.
I also do the same with the front control arm bushes (just below the footwells) since I can't get the solid M3 bushes here.
maxfield
Got the inserts here if someone wants to make me an offer?
