bolt in cage for 2 door 325i
dph500
What is the best/easiest cage to fit?
cheers
cheers
SteMarsden
I have fitted a Sparco FIA cage recently (with doorbars) which seemed the best compromise between cost and fit....
OMP cages have been reported to be 'difficult' to fit, and Safety Devices are very good (and British!) but were substantially more expensive than than the £455 I paid for mine.
HTH.
HTH.
BMW E30 318i ex PBMWC track car
2011 VW Passat Est
2011 VW Passat Est
Mikey_Boy
Hi there,
Just fitted a Safety Devices 6 point cage to my 2 door 325. It was pricey, but also pretty easy to fit as well - nothing needed messing with or changing - worth the effort for sure. Got mine from Automac (www.automac.co.uk).
If you are doing a trackday car, then I would try and get a cage with a diagonal and harness bars if at all possible - better rigidity and correct harness angles etc etc - depends on what you want - there's a cage out there for you!
Good luck with the project!
Cheers,
Mikey_Boy
Cheers,
Mikey_Boy
initial_g
- E30 Zone Moderator
omp are very difficut to fit, worse to remove tho i cant get the front part out mine to paint im gona have to do it in the car
Mikey_Boy
Whoooops! Didn't realise I would be 'pinged' for dropping in a supplier name... Rest assured I don't work for that company or endorse their products... Just bought a cage from them.
Mikey_Boy
Mikey_Boy
ijahn2000
I have a Safety Devices 18 point bolt in. It comes with harness bars and door bars inclusive.
The cage also triangulates to the rear suspension mounts, thereby removing the need for a rear strut brace. It also has fitments to add a front triangulation kit to stiffen up the front towers.
The downside is that you need to cut into the dashboard for the fitment, which makes it a bit harder
I paid about approximately £850 for everything a year ago for everything.
Let me know if you want photos or supplier details.
Ingo
Ingo
dph500
cheers guys, ordered up a sparco
SteMarsden
Good man.... let us know how you get on and get some pics up!
Mind letting us know how much? and whether it was an FIA cage?
2011 VW Passat Est
2011 VW Passat Est
e30cossie
I have a saftey devices 6 point cage for sale £500
UweM3
18 point bolt in?? I have WELDED 11 points and I wonder where the other 7 points are where you can bolt something to.ijahn2000 wrote:I have a Safety Devices 18 point bolt in. It comes with harness bars and door bars inclusive.
Ingo
Can you post a picture please, I am really curious
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
MrBenn
I've got the same cage, I only used 16 of the mounting points as I couldn't quite figure out the last 2. I've marked the 16 I used on the photo below. The other 2 were supposed to go on the front legs and bolt to the chassis about half way between the floor and the two points that go into the existing threaded hole in the front screen pillar.UweM3 wrote: 18 point bolt in?? I have WELDED 11 points and I wonder where the other 7 points are where you can bolt something to.
The circular mounting point (the other is obscured by the chair) shown near the bottom left has a long bolt that goes through the rear subframe bush, the other two at the very bottom go through the rear bulkhead and onto special brackets that sit on top of rear suspension turrets, shown below.
It also goes behind the dash.
universal
MrBen, is that the B7 safety devices cage?
MrBenn
No, this is the lesser known about B6. There is an upgrade kit for this too which goes through the bulkhead to the front suspension towers, about an extra £150.universal wrote:MrBen, is that the B7 safety devices cage?
UweM3
I can see how you came up with the number now. I was only counting my main connections. If I add the smaller points as well I may end up with 50 points....MrBenn wrote:I've got the same cage, I only used 16 of the mounting points as I couldn't quite figure out the last 2. I've marked the 16 I used on the photo below. The other 2 were supposed to go on the front legs and bolt to the chassis about half way between the floor and the two points that go into the existing threaded hole in the front screen pillar.UweM3 wrote: 18 point bolt in?? I have WELDED 11 points and I wonder where the other 7 points are where you can bolt something to.
The only additional main connection I have is the rear diff.
universal
may i ask where you got that one, and how much?
MrBenn
Power Developments in chesterfield, was £850 delivered I think.
