http://www.rallydesign.co.uk/product_in ... 25a5af88ea
If i were to use my existing shocks what else do i need to buy besides the springs ?
Are my original rubber top mounts OK ?
Talking of springs, what i want to do eventually is have one set for the road and the other for track days. I don't want these so i can lower the ride height very low, i want if i can to be the same as where it is in the picture below.
What LBs/length springs should i start off with ?
Is it worth trying to find some where that will zinc plate the threads for me ?
I'm not too fussed for true coil overs on the rears but i want to try and get some of those adjustable perch type things(like i think you get with a H+R coil over set up ?) that let you use the coil over sized springs so i can have the fredom to play with the rears, where can i get these from ?
