Big Brake Kit recommendations
gareth
You know you usually buy me a rubbish christmas present, well here's your chance to redeem yourself!
keri-WMS
Just a heads-up as we're down to the last few days where if anyone wanted to order a kit now I can just about keep it at 17.5% vat instead of 20%.
The reason is that HMRC has made a rule that as long as something is paid for before the vat rate goes up in Jan, the "vat date" can be in Dec (17.5%) instead of being the shipping date (which is the usual rule, and forces the vat to 20%).
So if anyone wants to dive in and save that extra 2.5% drop me a PM ASAP!
furbster
Sorry for such a long delay!! I've kinda been moving house and have been away from the pc.Could you post some photos of your discs please? There looks to be a lot of surface rust from the discs on the pads - if your discs are rusty they will of course increase the rate the pad abrasion / wedging effect occurs compared to a clean disc? This normally means the outer pad in each caliper wears faster then the inner as the inside face of the disc is protected from the elements and stays rust-free!
Please see below for the pics both of the offending disc on the car and then removed and cleaned.
The track day I spoke of was cancelled due to the snow, I managed to get some Willwood Poly B's and will report back after my next track day at Anglesey at the end of this month.
keri-WMS
No problem! That disc does look very corroded doesn't it - you need to get those rust lines gone completely or they'll cause a hot-spot that distorts the disc. They look like they are caused by water sitting in the groove in the pad (rusting the disc) while the car's not being used? Also the inner mounting face of the disc is too corroded, so the hub probably is as well?furbster wrote:Sorry for such a long delay!! I've kinda been moving house and have been away from the pc.
If the car's stood up outside it might be worth "bagging" the front wheels up to keep the rain out, otherwise this will keep happening!
furbster
Hmmm, it lives in the garage?
keri-WMS
Really? I'm even more confused now, why's it all getting so corroded, even the hub mount face?
The other thing to watch for is stopping the car on hot brakes as it can leave a pad-print, remember the cool down lap (for the rest of the car as well).
furbster
I know, it doesn't make sense. I totally understand what you are saying re the rust lines. The pics were taken when I had only cleaned them with brake cleaner. I got rid of those lines with a light emery cloth and more brake cleaner prior to refitting. I do always do a cool down lap, well half a lap at least. The only thing I can think off for the excessive corrosion was maybe not washing the car down thoroughly enough after a drift day at Oulton in the snow where they kept spraying the surface with salt water to keep the tyre squeal down. ( they cleared the snow in the morning) and had to use salt water because of the freezing temps.
keri-WMS
Ah, could well be - in any case the trouble with uneven pad material transfer is anything that sets up a hotspot on the disc will start the process (disc runout, rust or a pad print etc), and once it's happened its hard to reverse.
A good sanding (back to 100% bare cast iron) and new pads might do the job as you are nearly bedding the friction surfaces in from scratch, let me know how you get on!
SHAKEELE30
- Boost Junkie
keri do you do rear brake kits ?
Jozi
Think he has one in the making, unless I understood the post on the last page wrong: http://www.e30zone.net/modules.php?name ... 08#2052908SHAKEELE30 wrote:keri do you do rear brake kits ?
keri-WMS
We have indeed got one in the works (290mm vented 2-pot retaining the handbrake), one is already in Beta testing:
SHAKEELE30, are you just insterested in the rear or potentially the front as well?
SHAKEELE30
- Boost Junkie
keri just the rear as ive already got some for the fronts....
any idea of price etc
keri-WMS
The projected pricing is:
RB001 rear 290mm kit = £414.30+vat (discs, brackets, calipers, bolts)
Brake lines = £32.51+vat
With luck I can shave some off this when I get the first batch machined....
keri-WMS
I generated the brake bias info for the E30 vs WMS kits a while back, and I was sure I'd posted it up here, but I can't see it!!!
So here you are, numbers for the crunching (showing the bias is nearly kept at factory, and that piston area has a bigger effect than bigger discs!):
-----in other random news------
Just a bit of a random update on Dave Chant from earlier in the thread who's running WMS gear, he actually took the Dunlop TVR Challenge title and with it the TVRCC Challenge Cup in the final round of last year's competition at Oulton Park in spite of having a Class C car (Clas A and B are both faster regs)!keri-WMS wrote:Here's Dave in action, calm and restrained.....!
groselha
Has any of these kits been tested with the Schnizer 16" wheels?
keri-WMS
No-one has tried as far as I know, but you could try the PDFs against the wheel yourself?groselha wrote:Has any of these kits been tested with the Schnizer 16" wheels?
4P025 - 280x22 size kit (printable clearance test profile: 280x22 kit PDF )
4P028 - 298.5x24 size kit (printable clearance test profile: 298.5x24 kit PDF )
Let me know if that makes sense!
groselha
I'll test it, in the weekend.keri-WMS wrote:No-one has tried as far as I know, but you could try the PDFs against the wheel yourself?groselha wrote:Has any of these kits been tested with the Schnizer 16" wheels?
keri-WMS
Cool, let us know what you find!groselha wrote:I'll test it, in the weekend.keri-WMS wrote:No-one has tried as far as I know, but you could try the PDFs against the wheel yourself?groselha wrote:Has any of these kits been tested with the Schnizer 16" wheels?
groselha
Only this weekend had the time, to take some pictures, so here they are...
The wheels: AC Schnitzer 16" 7.5j et25
4P028 - 298.5x24 size kit:
4P025 - 280x22 size kit:
The 280mm kit is fine, lots of clearence, but the 298.5mm kit, i think it should be fine with the 2mm spacer, what you think?
For sure, it will be my first option for upgrading the brakes, when i finish the rebuild of my engine.
The brake kit for the rear wheels, seems to be interesting to.
keri-WMS
Sorry for the slow reply!groselha wrote:Only this weekend had the time, to take some pictures, so here they are... The wheels: AC Schnitzer 16" 7.5j et25
The 280mm kit is fine, lots of clearence, but the 298.5mm kit, i think it should be fine with the 2mm spacer, what you think? For sure, it will be my first option for upgrading the brakes, when i finish the rebuild of my engine.
Thanks for taking the photos, they are really handy. It looks like there's 2-3mm of clearance there? If so that's just about enough, so you shouldn't need spacers...
Jozi
Just found the templete in a box (moved house 2x in the last 7-8 months) only tried the 298 templete and unfortunately I will need different wheels, or maybe you can come up with a better fitting key?
Borbet B 16x9J ET15 - the caliper touches to the very left, it's at a slant there in the picture.
I can try a 16x7.5J ET20 one as well if you want?
keri-WMS
That's annoying, wheel inside profiles drive me mad! Thanks for doing the test though, really handy info. Could you possibly try three variations?Jozi wrote:Just found the templete in a box (moved house 2x in the last 7-8 months) only tried the 298 templete and unfortunately I will need different wheels, or maybe you can come up with a better fitting key?![]()
- 16x7.5 / 4P028 (in case the wheel shape is more useful)
- 16x9.0 / 4P025
- 16x7.5 / 4P025
Fingers crossed there will be a combination that fits.
D3mon_Hunt3r
How is that rear kit beta test coming along?
I'm interested in a front + rear kit.
keri-WMS
PM sent, sorry for the delay!D3mon_Hunt3r wrote:How is that rear kit beta test coming along?
E30_Crazy
And the verdict....?D3mon_Hunt3r wrote:How is that rear kit beta test coming along?
DasChin
i am running the RX7 4 pot kit with 280 mm discs and race hawk pads on my E30 track car with the 3 litre M3 lump in it.
car is light so more than up to the job. pretty cheap conversion too.
see pic:
the bloke who looks after my car has his wilwood 4 pots up for sale with 280 mm discs too if that helps? he was running that set up on his E30 with 15 inch ATS rims. good ET of 15 and 8J rims.
HTH.
see pic:
HTH.
dubownerbilco
keri! i have pm'd you a couple of times regarding brakes over the past 3 weeks and still no reply
i would appreciate a hasty reply please
keri-WMS
For the rear kit? Theo's been giving the first one a good thrashing and it's been going well! See: http://www.e30zone.net/modules.php?name ... &start=595E30_Crazy wrote:And the verdict....?D3mon_Hunt3r wrote:How is that rear kit beta test coming along?
Are you also interested in F+R kits?
keri-WMS
That's Re: VW brakes? I didn't get a chance to look at it properly, I'll do that now...dubwonerbilco wrote:keri! i have pm'd you a couple of times regarding brakes over the past 3 weeks and still no reply![]()
E30_Crazy
Been following for a while, and yes pretty interested in how these would do as a F+R kit. I just didn't know if the rears have options like the fronts do. And how many greenbacks it's gonna take...keri-WMS wrote: Are you also interested in F+R kits?
keri-WMS
Most of the same pads should be available, are those what you mean by options?
In terms of pricing the rear may be:
Front prices are all on the first page of the thread: http://www.e30zone.net/modules.php?name ... 9&start=24
E30_Crazy
That, yeah, and grooving or what-have-you. That allows a little better cooling, iirc? Would the 5% zone discount still be on each kit, or applied after total price of kits, pads, and lines?
D3mon_Hunt3r
Keri i sent you an PM, don't know if you saw it, it's still in my outbox.
keri-WMS
Grooving would still be available as an option for those that want it - but it's not really got much of a performance advantage these days as modern pads are far better at not gassing as they get hot. Grooved don't help to any real degree with cooling, nowadays it's mainly to reduce glazing on race pads, and also we find it helps reduce brake squeal if it occurs.E30_Crazy wrote:That, yeah, and grooving or what-have-you. That allows a little better cooling, iirc? Would the 5% zone discount still be on each kit, or applied after total price of kits, pads, and lines?
The 5% applies to the kits (front and rear) but not the other bits (pads / lines / spacers).
I'll get on to that now!D3mon_Hunt3r wrote:Keri i sent you an PM, don't know if you saw it, it's still in my outbox.
20vt
i'm interessed in a set off 280mm for the back retaining the hand brake... how mutch euros and time ;)
cheers
cheers
