Which Coilover set up for track day cars?
Lloydie38
Sun Sep 28, 2008 9:13 am
I think it's time to get some coilovers for the 325 track car, is there a group buy on these and what manufacturers do people rate and prefrences on set up?
I've currently got the bilstein sprintline set up on mine and it's great but it's time to move up I think..
JimmyC
Mon Sep 29, 2008 5:06 pm
I have just secured a "zone" deal on GAZ GOLD coilovers, will get full details up tomorrow :)
felstmiester
Mon Sep 29, 2008 5:57 pm
JimmyC wrote:I have just secured a "zone" deal on GAZ GOLD coilovers, will get full details up tomorrow :)
I'm interested in this as well. Keep us posted.
Dave.
northloop
Tue Sep 30, 2008 2:12 pm
Running H&R coilovers on mine which I think are brilliant. Going to try some harder springs on the back to change things a little though.
furbster
Tue Sep 30, 2008 10:50 pm
I'm running Leda coilovers which I would recommend to anyone! :cool:
Theo
Wed Oct 01, 2008 12:45 pm
C'mon Jimmy, spill the beans :)
handpaper
Wed Oct 01, 2008 1:00 pm
Are these front and rear coilover, Jim? I have GAZ coilovers at the rear, which I'm very happy with. They don't seem to corrode, either.
Gary, your rear springs are perfect - for the Nordschleife, which the car hasn't yet been to :chuckle:
JimmyC
Wed Oct 01, 2008 1:06 pm
Front and rear, including rear rose jointed topmounts just got to type all the detail up and get approved by GAZ, will also look at a price for inserts and telescopes
Will do the email to them now as off to SPA tomorrow :) and post up today it starts with a £6xx ;)
Theo
Wed Oct 01, 2008 1:24 pm
Sounds very good!
Good luck at Spa, me = jealous.
JimmyC
Wed Oct 01, 2008 1:28 pm
Theo325 wrote: Good luck at Spa, me = jealous.
me= bricking it! especially as forecast is for sleet!
Theo
Wed Oct 01, 2008 2:04 pm
Flat through Eau Rouge?
Err, maybe not.
Wed Oct 01, 2008 2:10 pm
Theo325 wrote:Flat through Eau Rouge?
Err, maybe not.
:rofl:
When I make the trip to 'Ring I am hoping to tie it in with Spa also :cool:
JimmyC
Wed Oct 01, 2008 4:36 pm
paulg390
Thu Oct 09, 2008 9:53 am
Sorry if this is a real numpty question :o: but what are the main advantages of a coil over set up over, for example, the full H&R cup set up we have at the moment which seems excellent for track use ? :?
White 318iS, 2.7 conversion, LSD, H&R cup kit, ARBs, F&R strut braces, full cage, kevlar buckets, wilwood 4 pot brakes, braided hoses, 6pt harnesses, f/glass bonnet, Toyo 888's, scorpion, polybushed, carbon cards and boot lid.
Thu Oct 09, 2008 1:04 pm
choice of springs
height adjustability
UweM3
Thu Oct 09, 2008 1:17 pm
Jhonno wrote:choice of springs
setting the corner weights!
Thu Oct 09, 2008 1:57 pm
with coilovers? :?
Explain :)
handpaper
Thu Oct 09, 2008 11:50 pm
Fine adjustment to the height of each corner of the car allows you to adjust the amount of (rest) weight on each wheel. The idea is to get the diagonal totals the same.
UweM3
Fri Oct 10, 2008 9:10 am
handpaper wrote:Fine adjustment to the height of each corner of the car allows you to adjust the amount of (rest) weight on each wheel. The idea is to get the diagonal totals the same.
What the man said :D
Fri Oct 10, 2008 9:48 am
That is what I thought it might be.. I assume all being well the differences required in height will be small enough not to affect the handling other ways? Or am I thinking too much?! With the corner weights the same the car is 'neutral'
How would you set corner weights? 4 wheel scales?
UweM3
Fri Oct 10, 2008 12:27 pm
Jhonno wrote:That is what I thought it might be.. I assume all being well the differences required in height will be small enough not to affect the handling other ways? Or am I thinking too much?! With the corner weights the same the car is 'neutral'
yes 4 scales and a very even floor. Most professionals do have 4 equalli leveled stand high enough to adjust the car whilst on the scales.
picture from Northampton Motorsports website
Fri Oct 10, 2008 12:37 pm
