Head light plugs
Hi Jon,
Do you still sell the connectors for smiley lights please ?
Cheers Mart.
Cheers Mart.
Cotswoldbmw
Hello Mart
I will need to know the colour and there will be a part number on the original ones.
Jon
Jon
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
Hi Jon, I may need to get back to you as all is not what it should be under the bonnet.Cotswoldbmw wrote: ↑Tue Oct 29, 2019 4:09 pmHello Mart
Jon
Cotswoldbmw
No problem, let me know.
Jon
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Tzantushka
Yellow 1378419
White 1378417
I recently ordered 2 of each to replace my plug housings for the back of my headlights.
Check the part numbers as these were for an Aussie delivered Euro spec 320i
Cotswoldbmw
Hello Mart
They are plug connectors but our info does not show them having a specific function ie headlamps
419 £4.32 each
417 £3.71 each
Let me know.
Regards
Jon
419 £4.32 each
417 £3.71 each
Let me know.
Regards
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Cloggy Saint
As above. Colour is what matters.
Cloggy Saint
Because they have subtle differences in shape that prevent them being plugged into the wrong socket.Cloggy Saint wrote: ↑Fri Nov 01, 2019 11:52 amIf they all do the same job then I don't see why the colour matters!
Cloggy Saint
There's a limited number of shapes that can be made! They're only different when there's a chance of them being fitted in the wrong sockets.
Not much chance of the diff. plug being plugged into a headlamp, so the same pattern can be used.
Hi Jon, do they come with a small length of wire with them please ?Cotswoldbmw wrote: ↑Fri Nov 01, 2019 10:27 amHello Mart
419 £4.32 each
417 £3.71 each
Let me know.
Regards
Jon
If so the I will have two of each please
flybynite
No you need to get the correct waterproof wire connectors that clip in to the coloured shell. They only have green wire. You need 2 per plug
There are straight and angled connectors of a few sizes depending on the plug you have. I had to do a bit of trial and error to find the ones I needed
Satan
If you use a molex pin removal tool then you can the pins out of the original plug.
https://www.ebay.co.uk/p/21pcs-Car-Wire ... M0QAvD_BwE
You can out of some of the multiplugs, but not these water resistant ones.Satan wrote: ↑Sat Nov 02, 2019 8:45 pmIf you use a molex pin removal tool then you can the pins out of the original plug.
In a lot of cases it's just the outer coloured shell that's required to get things back to 'as new'. The only time the buckets need renewing is when the insulation on the wire has cracked close to the bucket, and in these cases I've always used one from scrap loom and spliced the wires together.
flybynite
But isn't Mart converting from Pre FL lights??
From what I remember from over 25 years ago when I put smileys on mine the Pre-FL had simple spade connectors held in a black frame. To convert to bullets or smileys properly you would need to splice in the green tails (or donor pig-tail cuts) in place of the spades then clip in to the coloured plug housing. Which plug into the back of the Smiley/Bullet
Oh but keep the old connectors you cut off in case (as I am) you end up going back to original one day
Even better put some spades on the other end of the smiley wiring to plug into the pre-FL headlight socket making an adapter lead
Trust me there are lots of ways that plug can be made, I have quite a selection of wrong shapes. Nothing that cannot be fixed by rounding a square off with a stanley blade but if you are doing it properly…..Brianmoooore wrote: ↑Fri Nov 01, 2019 1:48 pmThere's a limited number of shapes that can be made! They're only different when there's a chance of them being fitted in the wrong sockets.
flybynite
Too many years of doing it that way, got to fight the urge. Bodges the proper way, done a couple of decades ago are still going strong but I am still going to rip them out and put it back as the gods at BMW intendedBrianmoooore wrote: ↑Sat Nov 02, 2019 10:24 pmIt's not just me then! Same thing with the wrong key in a lock barrel and a file.
Satan
You two should work together.........flybynite wrote: ↑Sat Nov 02, 2019 11:04 pmToo many years of doing it that way, got to fight the urge. Bodges the proper way, done a couple of decades ago are still going strong but I am still going to rip them out and put it back as the gods at BMW intendedBrianmoooore wrote: ↑Sat Nov 02, 2019 10:24 pmIt's not just me then! Same thing with the wrong key in a lock barrel and a file.stop them turning in their grave before I join them
Strangely enough, I used to often do work for a small building firm whose trading name actually was Bodgit & Scarper.
Do you have a link for these or better still can you remember which ones you used ?flybynite wrote: ↑Sat Nov 02, 2019 3:59 pmNo you need to get the correct waterproof wire connectors that clip in to the coloured shell. They only have green wire. You need 2 per plug
There are straight and angled connectors of a few sizes depending on the plug you h2ave. I had to do a bit of trial and error to find the ones I needed
I have had a look at mine and the "white " plug is straight and the "yellow" is at 90 deg`s.
flybynite
Hi Mart
What I got probably not much use to you as it was not for headlights, it was for something completely different
I have just had a look at the back of the headlights on my early facelift (fitted with bullets) it has a white plug for the main beam and a yellow plug for the dip beam. Both straight plugs, stamped with 'bmw' but helpfully no part number on either of them.
I have checked the realoem pages and it seems to show angled for both
https://www.realoem.com/bmw/enUS/showpa ... 1131378419
Linking them to an ebay seller who tends to have good photos and they are again both angled
https://www.ebay.co.uk/itm/BMW-Wiring-C ... Sw8xxckrn-
https://www.ebay.co.uk/itm/BMW-Wiring-C ... Sw6JZckrtd
Either way you need (1,0-2,5 MM² cable for headlights)
61130007442 for the straight connector
61130007446 for the angled connector
From this page
https://www.realoem.com/bmw/enUS/showpa ... 1130007441
The pictures in the ETK(realism) are just generic drawings of an electrical plug and may not look anything like the actual item.
flybynite
Agreed, you need to look at the drawing but also search pictures of the part number it shows to see what the item actually looks like, which is why I tend to put the part number into google or ebay.Brianmoooore wrote: ↑Sun Nov 03, 2019 7:10 pmThe pictures in the ETK(realism) are just generic drawings of an electrical plug and may not look anything like the actual item.
In this case they were accurate, it showed the difference between a (generic) angled plug and the straight one.
Hi Jon two of each please mate even without cables.lolCotswoldbmw wrote: ↑Fri Nov 01, 2019 10:27 amHello Mart
419 £4.32 each
417 £3.71 each
Let me know.
Regards
Jon
Cotswoldbmw
Hi Mart
£16.04 in total then.
The above price is valid for 7 days from today.
All prices quoted are for Genuine BMW / MINI Parts, include discount for enquiring online and VAT and postage.
YOUR CUSTOMER ORDER REFERENCE NUMBER IS - P60620
Payment Options:
For orders under £500.00 and if the delivery address is the same as the registered card address.
Call 01242 335365 with your card details and customer reference number or via Paypal / Bank Transfer (Details Below)
If you would like the delivery to a different address then we can only accept Payment via Paypal or Bank Transfer
For orders over £500.00 we will only accept either a bank transfer or payment by Paypal.
Paypal – partscheltenham@cotswoldgroup.com
Please send payment as a gift to friends and family with your customer reference and your delivery address in the notes section.
Bank Transfer – Sort Code 20-07-71 Account Number 40292230 with your customer reference in the notes section but please call or email us with your delivery address.
PLEASE PROVIDE US WITH YOUR VEHICLE REGISTRATION OR CHASSIS NUMBER TO SECURE YOUR 2 YEAR MANUFACTURERS WARRANTY
Many Thanks
Jon
Payment Options:
Many Thanks
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Tzantushka
Hopefully I can make a useful contribution to this forum than merely banter.
A picture is worth a thousand words!
Yellow 1378419 (90 degree cable exit)
White 1378417 (90 degree cable exit)
Appears a different part number for the yellow connector where the cable exits straight out the back
Yellow 1378403
Yellow 1378403
Sorted Jon, cheers Mate.
Cotswoldbmw
Hello Mart
Glad to help.
Jon
Glad to help.
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Arrived today, top draw as always Jon
Cotswoldbmw
A pleasure to serve
Cotswold BMW Parts
01242 335365
01242 335365
