m42 bottom end rebuild
Looking for genuine BMW parts at discounted prices? Try here!
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Fri Jul 25, 2008 11:31 am
Hi Paul,
You you quote up for the following please mate:
Con-rod and crank bearing shells: (not sure what size yet)
http://www.realoem.com/bmw/showparts.do ... g=11&fg=20
Timing chain guides, tensioner:
http://www.realoem.com/bmw/showparts.do ... g=11&fg=25
Chain case gaskets and crank seal:
http://www.realoem.com/bmw/showparts.do ... g=11&fg=10
Exhaust manifold gasket:
http://www.realoem.com/bmw/showparts.do ... g=11&fg=50
Water pump and thermostat:
http://www.realoem.com/bmw/showparts.do ... g=11&fg=35
Hoping I don't need to do the chain itself. Are there any other parts that it's good to replace at the same time??
frogman
Sun Aug 03, 2008 10:59 am
what mileage is on the engine?
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Mon Aug 04, 2008 1:25 am
about 120 mate.
HarvyS
Wed Aug 06, 2008 11:02 pm
Hoshy, I asked the parts guru for the price of shells a while back as im going to be doing mine when i get some money together and he quoted me as follows:
Big end shells: £66.13 (set)
Main bearing shells: £88.40 (set)
But hed need to know the color mark on the con rod and main bearing. hope this helps!
Harvy.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Thu Aug 07, 2008 12:06 am
phew - fair price then.
Any idea what the procedure is for taking proper measurement of these things?
HarvyS
Thu Aug 07, 2008 12:13 am
I Know i thought they would have been a lot more than that. Im not sure bout the procedure for the proper measurment but there are dots of color on the con rod by the big end and then on the crank but the main end and the guru said he could order the right shell size by just knowing those colors. I think mine were a yellow dot on the con and a blue dot on the crank but i cant remember. hope that made any sense! lol!
Harvy.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Thu Aug 07, 2008 1:07 am
oh interesting. I thought it was the case the the different sizes were to accommodate for wear or something. it makes perfect sense.
