E30/34/32/36 LSD DIFF QUESTION
320ise
is the internals of the diff the same in all these forgive my lack of knowlage on this! i know there are different size casings etc but if i got a very cheap 525i sport lsd (bin offerd one for £20 at local breakers as he dont know its a slipper and dont really care lol) could i take the lsd part out (or the whole internals) and build into the correct size casing for my car? i am looking at doing this for my e30 320i and maybe a e36 325i allso what should be looked at or inspected when rebuilding into new case etc? any information would do thanks! is the slipper part in the diff the bit that sets the ratio or just the bit that enables it to lock?
Yaninnya
It is a 188 diff so take it. For E30 you only need to change back plate. E36 have different casting but you can use internals.
Jan
Jan
320ise
what does 188 mean i am dumb for diffs lol
Yaninnya
BMW is makeing three types of diffs: small case - 168, medium case - 188 and big case - 210.
And I just realised that I made mistake. I understand that this 525i is E34 not E28. Then you can use only the LSD. The case is different.
Jan
Jan
320ise
is the lsd easy to put into new case allso if putting into a e36 325i std case what ratio would this then be?
Yaninnya
Yes and no. You really need to know what you are doing. LSD have nothing with diff ratio so the ratio will be the same.
Jan
Jan
320ise
any one got any info or pics of how i would do this?
oldroydsr4
if your asking for pics, my guess is that it would be best to send to a specialist.
320ise
i am a fast learner and that comment was not really helpful i want to learn and if i had the money to take it to a specialist i would!
oldroydsr4
sorry if it was unhelpful but diff rebuilds are expensive for a reason.
