Changing Diff Ratios (opening the diff up)
Danny_boykk
Post Fri Jun 15, 2007 4:38 pm
What is involved in changing a 3.23 LSD diff internals from an E36 M3 evo up to a higher e.g. 3.64 LSD ratio. In detail please as im a bit of a mechanical noob.
**BANNED**
Post Fri Jun 15, 2007 5:42 pm
If you are a 'mechanical noob'leave well alone!!Best option is to sort out a complete diff of the spec you want and swap that in.
Danny_boykk
Post Fri Jun 15, 2007 6:17 pm
There is no other compatible diff on the evo. If you told me what to do I could give it a try, I mean how hard can it be, unbolt diff from car, open diff change gear/sprocket over and torque to correct, fill up with royal purple and then rebolt on car - but I need to know the specifics.
Post Fri Jun 15, 2007 7:28 pm
Specialist job, end of :)
Post Sat Jun 16, 2007 10:24 am
Danny_boykk wrote: I mean how hard can it be, unbolt diff from car, open diff change gear/sprocket over and torque to correct,
Requires specialist knowledge, skills and equipment. Even changing the pinion seal requires a special procedure.
snoops
Major Helmet
Post Mon Jun 18, 2007 9:14 am
just sell it and then buy a 3.64 lsd from a tech 1 sport :wink:
e30_Turbo
Boost Junkie
Post Mon Jun 18, 2007 12:41 pm
Having just had a LSD diff fully rebuilt with new ratios I can assure you it's a skilled job.
My costs were £250 on top of the LSD unit and the CWP.
So overall £400+ was spent, bear in mind they normally go for around the £250 mark, so I'd buy another.
( I need a ratio that I couldn't find anywhere with a LSD, hence why I spent the money )
HTH, Mark.
