635 diff
curryp
- Formerly cuzz1510
i know its in the wrong forum, but does anybody know if a 83 84 635csi diff is lsd? also what ratio is it? cheers
HairyScreech
ill ask on sat if no one on here answers before then, ill be up working on a 6 then.
LSD was optional, usually a 3.07 ratio, and no it will not fit an E30 !
curryp
- Formerly cuzz1510
kam-325i
anything will fit with modification.
cuzz1510 wrote:it fits the m3 prop with slight modification according to the engine conversion specialist i spoke to:?
Ask him how much, and when he can fit it, and then watch him go quiet !
Andyboy
- Alpina Colada
No it doesn't! He's talking bollocks.cuzz1510 wrote:it fits the m3 prop with slight modification according to the engine conversion specialist i spoke to:?
curryp
- Formerly cuzz1510
roger that gents.it was fritzsbits who said it could and iv read it on net somewhere before (cant remember where though)
but if you say so......
Andyboy
- Alpina Colada
They ought to know better - you buy a 635CSi 210 diff and drop it off with your car for the 2 hours it takes for a straight diff swap............cuzz1510 wrote:roger that gents.it was fritzsbits who said it could
A 635CSi diff WILL bolt to the E30 axle carrier because the four bolt spacings are the same. However you will need custom driveshafts because no E30 outer CV will bolt to the 635CSi diff flanges and 635CSi outer CV's will not fit any E30 drivehaft known to man. E30 diff flanges will not fit a 635CSi diff.
As well as a pair of custom driveshafts you will need a custom rear diff mount because the rear diff mounts are of two totally different types so you would need to have a special diff carrier welded to the boot floor. Then of course you will need to have a shorter prop with a 635CSi end yoke fitted. Then you will find the 3.07 ratio is completely wrong unless you have a 1:1 ratio sport gearbox.
See where we're coming from? We were all trying this LONG before Fritz Bits came along!
Alles Klar?
eko
- Old timer
Could the internals from the 635 diff be transfered over to an E30 diff?
Andyboy
- Alpina Colada
No. It uses the big 210 diff and nothing fits as it's all too big. Forget the 635CSi diff!!eko wrote:Could the internals from the 635 diff be transfered over to an E30 diff?
curryp
- Formerly cuzz1510
Yaninnya
Nein, nicht Alles! Ich möchte mehr Ãaber Ausgang Flansche wissen!Andyboy wrote:Alles Klar?
And in english: do you know what is the difference in distance between output flanges 188 vs. 210 if there is any?
I hope you understand what I mean...
Cheers,
Jan
P.S. I'm not german and my deutch is very poor (it is just easyer to work on BMW with some basic knowledge of german, isn't it?).
Andyboy
- Alpina Colada
Are you for real?Yaninnya wrote:Nein, nicht Alles! Ich möchte mehr Ãaber Ausgang Flansche wissen!Andyboy wrote:Alles Klar?![]()
I hope you understand what I mean...![]()
Cheers,
Jan
binxy69
what if you were fitting an m30 engine and a manual transmission from a 635 csi into an e30? Would you meed a 3.07 ratio diff?
Andyboy
- Alpina Colada
No. Only the non catalyst cars up to mid/late 1987 used the 3.07 and they were really overgeared. Cat cars used a 3.45 and the Highlines used a 3.64 which geared them up just right. 5500 rpm was 140 mph with the 3.64, so peak power comes at max speed.binxy69 wrote:what if you were fitting an m30 engine and a manual transmission from a 635 csi into an e30? Would you meed a 3.07 ratio diff?
Yaninnya
Yes, absolutely. Do you know what is that difference?Andyboy wrote:Are you for real?
Jan
P.S. No offence, but it looks like we have different sense of humor.
Andyboy
- Alpina Colada
What are you talking about??Yaninnya wrote:Yes, absolutely. Do you know what is that difference?Andyboy wrote:Are you for real?
Jan
eko
- Old timer
Andy what model BMW will my diff have come from?
3.46 open!
3.46 open!
Andyboy
- Alpina Colada
Show us a pic of what you have!eko wrote:Andy what model BMW will my diff have come from?
3.46 open!
eko
- Old timer
No pic as such,but its whats in there!Andyboy wrote:Show us a pic of what you have!eko wrote:Andy what model BMW will my diff have come from?
3.46 open!
Yaninnya
I'm talking about 210 diff and.Andyboy wrote:What are you talking about??
From your previous posts I understood that you was trying to fit 210 diff from E23/E24/E28 to E30 rear subframe. Thats why I asked do you know the distance between left and right output flange in 210 diff. I hope that this time you will understand what I'm talking about.
Jan
P.S. English is not my first language.
Andyboy
- Alpina Colada
Understood. But I have no idea, all I know is the diff doesn't fit an E30 without a huge amount of work.Yaninnya wrote: Thats why I asked do you know the distance between left and right output flange in 210 diff.
I believe Fritz are developing an active ride set up for E21s , i wonder how its progressing............
curryp
- Formerly cuzz1510
are there any other diffs that will fit the e30 m3 prop then? having a bit trouble sourcing a 3.25 and dont wanna go near fleabay
Andyboy
- Alpina Colada
Not really. Maybe an early E28 528i diff.
