E36 compact pollen filter
jcjdavis1
Hi where is the pollen filter and how easy is it to change.I have tried a search but nothing turned up.Wife complaining of demisters not clearing screen. thanks
andrewe30m3
Ok, this ones easy, i changed the ones on the wifes car last week;
Open the bonnet and unclip the grill at the top of the engine bay, near where the wipers are.
You'll need a 7mm socket and a phillips screwdriver to undo the bit of trim with the loom attached to it. - pull this forward so you can gain access to the filters (yes there are two) replace them with the new ones.
then refit the parts you've taken off.
i hope this helps.
i hope this helps.
jcjdavis1
Hi and thanks will have a go when the rain stops.(looks like summertime)
jcjdavis1
Hi thanks to andrewe30m3 for his advice on changing pollen filters was spot on.
ivqii
- Regression is the way forward !
Dumb q perhaps - but what happens if they are left and not changed?
jcjdavis1
Heaters do not operate properly/demist not clearing screen.ivqii wrote:Dumb q perhaps - but what happens if they are left and not changed?
andrewe30m3
no problems. glad it helped...jcjdavis1 wrote:Hi thanks to andrewe30m3 for his advice on changing pollen filters was spot on.
