Hi can anyone on here tell me if E38 7 series wheels will fit a E34?
Thanks in advance
Rich
E38 to E34?
- Retired Team Member
- Contact:
some late e34 M5's have the M parallells fitted as std, PCD is the same, offset may be an issue though....
can you not try one to fit locally, then comitt funds ?
Email FTW
E38 wheels will fit straight on the E34. may need a small spacer on front depending on suspension and tyre choice. ,similer to some 325 E30's with rubbing on strut issues.
E38 has same centre bore as E34 72.5mm ,ET 20mm
while the E39 has a 74mm centre bore requiring spigot rings
Wheel/tire combination
15x7" Wheels (OEM)
205/65-15
225/60-15
16x7.5" Wheels:
215/55-16
225/55-16
17x7 - 7.5 - 8 - 8.5" Wheels:
235/45-17
255/40-17
18x8.5" Wheels:
235/40-18
245/40-18
265/35-18
19x9" Wheels:
245/35-19
275/30-19
Hope this helps
15x7" Wheels (OEM)
205/65-15
225/60-15
16x7.5" Wheels:
215/55-16
225/55-16
235/45-17
255/40-17
18x8.5" Wheels:
235/40-18
245/40-18
265/35-18
19x9" Wheels:
245/35-19
275/30-19
Hope this helps
