M52 Nikasil
SAP1
I'm looking to buy an E36 328i with under 100k miles. If it still has the Nikasil engine should I be worried?
jimmyspeed
what year is it?
nickso
- Location: Go do that voodoo that you do so welllllllll!!
If it runs Ok I wouldn't give it a second thought.
'88 e30 328i M52 track bint.
jimmyspeed
if its a sport the earlier cars came with a LSD which would be a bonus
darkchild
Its now 19 years old. Assuming its even still on its original block it'll be fine.
Andyboy
- Alpina Colada
Even so, Nikasil engines don't like lots of cold starts - that's what buggered them. So once it's started, try not to switch it off again until it's good and warm.
It may well have had a block swap by BMW in the past. Look at the back of the block below the starter and you'll see either a pear shaped casting lug (nikasil) or a rusty steel tag with a bolt (steel liner replacement).
Do a compression test if your worried, they still turn up now and again with no compression, usually through auctions
SAP1
Sorry for the late reply.
Went to look at the car it was a 1996 328i Moordoor.
The body work was decent but when looking at the car the cooling system pressurized and overheated, so I walked away there is plenty 328's out there so onto the next one
Thanks for the advice lads
Headgasket FTL
