2006 320i M-sport value
Theo
Post Wed Apr 16, 2014 12:17 pm
145k miles, no tax/test, needs a new alloy and rear wheel bearing.
Thoughts on value?
Post Wed Apr 16, 2014 12:54 pm
2k ish sounds about right. It will cost at least another £500 by the time it has some rent on it. Then you need to pray that the chocolate engine does not poo itself :(
I am guessing it might make 3.5 ish done and tested.
Theo
Post Wed Apr 16, 2014 3:51 pm
Thanks Pete, it's a quattroporte. Does that make a big difference?
Post Wed Apr 16, 2014 4:00 pm
I guessed as much :( Coupe is obviously much more saleable, M Sport innit :)
Even as a quattroporte, it is still a saleable turd, new shape M Sport innit :)
Theo
Post Wed Apr 16, 2014 4:25 pm
F*cking executive!
Is doing the wheel bearing is a simple enough job on these turds?
Andyboy
Alpina Colada
Post Wed Apr 16, 2014 6:48 pm
Not bad if you have the suitable pullers. These shitheaps love a rusted/broken ABS ring so it makes sense to fit a new one with the shaft out. They're about a tenner each and easy to fit.
Horrible N46 engine with the the attendant dramas.
Theo
Post Thu Apr 17, 2014 1:53 pm
Thanks Andy, what are the attendant dramas you speak of?
Post Thu Apr 17, 2014 2:53 pm
Pull up a chair , a cup of coffee and Google BMW N46 problems :(
On a positive note,at 145k , most of the issues should have been fixed, several times :)
darkchild
Post Thu Apr 17, 2014 5:01 pm
I had a N42 powered turd. The only car I've ever had where the dipstick rusted. Bought a replacement and that rusted as well. Horrid engines :(
Oh, and oil leaks...and coil packs...and everything takes hours to fix. A true legacy of BMW's time with Rover. :)
I should be grateful though. No timing chain tensioner issues when I owned it. :)
Post Thu Apr 17, 2014 6:33 pm
N42/N46.
BMW's worst engine ever!
Theo
Post Fri Apr 18, 2014 11:46 am
Sounds like these are real shit heaps
Post Fri Apr 18, 2014 12:22 pm
Theo wrote:Sounds like these are real shit heaps
Is it much cheapness ? :)
Andyboy
Alpina Colada
Post Fri Apr 18, 2014 12:32 pm
If it's 2 grand or so then you can invest £5-600 on a new chain/tensioner, fix the oil leaks and replace the TDC sensor. With luck it should be okay but you still have the VVT motor, eccentric shaft wear and that sort of nonsense. I wouldn't give one garage space myself.
But if you can turn an eric on it.......
Post Fri Apr 18, 2014 1:41 pm
Eccentric shaft wear problem was sorted by then.
The E9x 3 series is a good car on the whole, but yours is saddled with THAT engine.
What's happening with the Hartge?!
Theo
Post Sat Apr 19, 2014 7:09 pm
It is cheap, its one of our company cars which we're getting rid of. Its not had a nice life :(
Nothing is happening with Hettie, I want someone to do the work for me as I don't have the time.
mcbonio
Post Mon Apr 21, 2014 12:49 pm
Andyboy - the OPs car is a 320i which is M54B22 engine not a N42.
I'd say car was worth 2 - 2.5k depending on spec and condition.
Theo
Post Mon Apr 21, 2014 1:40 pm
It's a 4 pot banger so not an m54
Post Mon Apr 21, 2014 2:09 pm
mcbonio wrote:Andyboy - the OPs car is a 320i which is M54B22 engine not a N42.
It's an E90.
Post Mon Apr 21, 2014 2:30 pm
Theo is not stupid, he would not waste his time foook1ng about with old worthless E46 council frag ! :)
mcbonio
Post Mon Apr 21, 2014 9:29 pm
The first post doesn't say it's an e90, just that's its 2006. E46 ran until May 2006 also. My confusion is valid! :)
Post Mon Apr 21, 2014 9:44 pm
But we had already established MUCH earlier in the thread that it was an E90 with the nasty N46 engine .
The E46 saloon was replaced in late 2005 by the E90 but E46 convertibles and coupes soldiered on for another year
pony
Post Sun May 04, 2014 6:22 am
E90 saloon came out in 2005 plates
E46 3 Series Coupe built until May 2006
E46 3 Series Convertible built until August 2006
