Turbo's E36 ute...
leeparkes
Post Sat Dec 21, 2013 11:57 am
I kinda like this :)
http://www.ebay.co.uk/itm/BMW-E36-3-SER ... 19e608f900
ENGINE CAN BE RUN ON 6 OR 8 INJECTORS
Not sure what he means by this :?
maxfield
Post Sat Dec 21, 2013 12:16 pm
Car was 'built' in this neck of the woods.
Rather than use a management system. 2 extra injectors are plumbed in to compensate for the fuel of the turbo. :(
mcbonio
Post Sat Dec 21, 2013 12:18 pm
How can you turn on an extra 2 injectors? How can a 6 pot use 8 injectors? WTF?
maxfield
Post Sat Dec 21, 2013 12:20 pm
mcbonio wrote:How can you turn on an extra 2 injectors? How can a 6 pot use 8 injectors? WTF?
They will be in the boost pipe spraying before the throttle body.
And there will be a switch (probably a motorbike brake switch) on the turbo actuator, once wastegate opens will then bring the other 2 injectors into use.
Post Sat Dec 21, 2013 1:11 pm
A fith injector was a common mod on escort rs turbos back in the day which had Bosch KE jetronic fuel injection as the injectors were mechanical.
The fith injectors was normally an electronic one which was mapable with its own small ecu and map sensor.
leeparkes
Post Sat Dec 21, 2013 10:23 pm
Never heard of it...
I emailed the seller earlier with this...
Hi,
What management system does this engine run on? im a bit confused about using 6 injectors then 8?
His answer....
M3 management, why confused about 6 or 8 injectors as the pick-up has 8 injectors but can be run on 6 for economy at a flick of a switch.
M3 management :mad: sounds a bit lash up to me..
aze30
Post Sat Dec 21, 2013 10:55 pm
Hi,
His answer....
doesnt sound right to me....unless its running ms3 ecu? ms3 is a megasquirt.
if those other two injectors are plumbed in like said before they will be somewhere on the inlet plenum and hopefully in a place that will give all cylinders some equal fuelling im guessing/hoping..lol
maxfield
Post Sun Dec 22, 2013 4:20 pm
It will just be running on stock management.
The car will be a lash up.
There is a twin to this car, where a saloon was used.
That was an epic bodge.
Pacerpete knows what this lads work is like.
Phill172
Post Mon Feb 03, 2014 9:39 am
Been for sale for ages, looks like a sack of shit and wouldnt touch it with a barge pole
Again another heap that gives drifting is reputation.....
