Why, why, why!
http://www.ebay.co.uk/itm/BMW-Compact-3 ... 3915305%26
Really?
Andy325i
ross_jsy
Why what?
Those Rover v8's are good lumps
Andy325i
Sure they can be tuned, but in standard fettle they are far from quick compared to more modern BMW lumps
ross_jsy
Engine spec:
3.5 V8
Ported heads with kent double springs skimmed.
Hurricane cam
Std Followers
Adjustable push rods (Real steel bottom end bolts)
Timing button to stop float
Steal timing gears
Offy manifold with 600CFM double pump carb
Electronic ignition.
So had some work done. Cheap lump to throw in compared to a lot of modern BMW stuff
3.5 V8
Hurricane cam
Std Followers
Steal timing gears
Morat
I bet he's getting about the same power as an M30.
