Hello Ladies
Can anyone advise me on the best way to adjust my handbrake.
I have replaced the rear disks and handbrake shoes but I cant seem to get the handbrake to adjust up. Its either not effective enough or too tight causing binding.
Any idiots guides?
E39 Hand Brake Adjustment Help
scott180gtb
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Smellit
i had the same problem with mine, failed its mot so new pads discs and shoes went in and it failed again!!! so i took it to a different test station and it passed, never found out what caused it but the handbrake was never anygood reall unless i pulled it up with two hands
scjimbo
E39 hand brakes are total crap anyway.Smellit wrote:i had the same problem with mine, failed its mot so new pads discs and shoes went in and it failed again!!! so i took it to a different test station and it passed, never found out what caused it but the handbrake was never anygood reall unless i pulled it up with two hands
Why did it fail? Was it too many clicks or not efficient enough?
Smellit
not efficient enough, also was advised on "undertrays fitted" BMW put them there so dont know what they wanted me to do about it?
even all the adjusting i did made no difference.
irish320i
loosen the cables in the car, then through one of the wheel bolt holes at the back turn the little cog with a small screw driver, Adjust till the wheel locks then back of a turn. With this done on both sides adjust the cables.
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
Procedure is exactly the same.diable wrote:oooop my bad just noticed E39
There's nothing wrong with ANY BMW handbrake IF shoes that haven't already been ruined by misadjustment are adjusted correctly with the cables completely slack.
scott180gtb
Sorted this yesterday.
I followed the wiki link and backed everything off and started again. I fooking hate gravel driveway's in the rain.
Cars
